Water flow - Is it the faucet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mds, Jan 22, 2009.
  1. mds
    mds New Member
    Jan 22, 2009
    I did a major remodel and some of the faucets have good water flow, but many have suboptimal water flow. My plumber says it is the plumbing fixtures, not the pipes (all redone in copper) or any installation issues. I don't know how to assess this and I don't know how to fix it (short of replacing many faucets if that is the issue). I am in California that has low flow requirements. Most of the faucets are from Newport Brass.
    Any thoughts? If there is good (very good - and it is a different brand product) flow in one tub then can I assume that it is truly the faucets on the others (especially the other ones right near by)?
    Thanks,
    MDS
  2. hj
    faucets
    That would be the normal assumption, and because all the faucets other than the tub have maximum flow restrictions, it would be a very likely diagnosis, assuming the faucets are not plugged up, that is.
  4. mds
    mds New Member
    Jan 22, 2009
    Is there anything I can do about it short of replacing the faucets? Is there are way to reduce or eliminate the restrictors?
    Thanks,
    MDS
  5. hj
    faucets
    Usually you have to remove the aerators, but since YOU probably cannot buy unregulated aerators, you would have to live with a splashing sink faucet if you did it.
  6. mds
    mds New Member
    Jan 22, 2009
    Doesn't seem fair, but thanks for the feedback.
    MDS
Similar Threads: Water flow
Plumbing Forum, Professional & DIY Advice Where can backwater/backflow valves be used in a building? Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Increase flow from water line to fridge Nov 8, 2016
Plumbing Forum, Professional & DIY Advice Concerning backflow [water contamination] issue, advice needed Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Reduced Water Flow in Single Bathtub Faucet Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Drained water heater, flow worse Jul 26, 2016
