visiting my friend today to watch the Seahawks game (we won! 5-1 now! woo hoo!) and found that she is worried about this wall damage that has appeared between the toilet and tub/shower. She thinks it is new, but she has only lived there 6 months, and she doesn't usually use that bathroom. It is dry to the touch...but maybe it is wet inside the wall?
-- does this sort of wall damage occur from moisture inside of wall? or outside?
-- toilet supply is a little loose at wall. she turned off supply to toilet, but does that matter? if there was a leak in wall due to the loose supply having damaged a connection in wall, wouldn't it still be leaking in wall despite it being shut off to toilet?
-- her son was using that shower for 3 weeks while staying with her. could this be water damage from shower? this wall is shower head side...and uses a curtain.
so, can we turn the water back on to toilet? do we need to cut into the wall? and to what degree of urgency?
Thank you for your wisdom
