Water coming from vents in well cap
GB-man
New York State
Hello all thanks for taking the time to help me out. I’ve used this forum many times in the past for remodel plumbing information and it’s always been a valuable source as a simple reader of former posts and solutions.
I have recently purchased a property in central ny state that has a well. I do not know much about wells so here I am.
My well is spewing out clean water from the two dime sized screened vent holes under the metal cap. Is this just seasonal artesian flow or is it something I need to get plumber to address? Any help is appreciated.
GB-man
New York State
I don't know the answer to your question.
It already looks like your casing is out of the ground a fair amount. I wonder if extending the casing another 2 ft would help. If this is pretty much peak flow, it does not seem so bad to me. I am not a pro.
One thing I think I might do is to seal the top of the conduit with duct seal to keep the water from going down the conduit. I did that to prevent possible ingress of ants into my well. I shoved the duct seal in around the wires as best I could by hand.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
That is not the type of well seal that is supposed to be used on flowing wells. Take the cap off and have a look. Most likely there is a hole in the pipe or the pitless o-ring is leaking a spraying up to the top of the well seal. Does the pump come on when no one is using water?
