Another washing machine shut off valve question. My currently leaky valve is a threaded boiler drain valve that is soldered on to the pipe. Is it better to replace with the same thing? Or should I get a compression valve? I haven’t seen any sweat type valves for washing machine shut off and only found the compression type online. Also can I use a boiler quarter turn ball valve and sweat it on or will that damage the valve?
Thanks! You all are always such a huge help!!
