Wash basin drain
graemew
Alberta, Canada
I have a 2" metal standpipe that my washing machine drains into. The standpipe is about 3' tall. I would like to install a wash basin beside the washing machine, but the basin drain is less than 3' above the ground. Does anyone have a recommendation for connecting the basin drain to the standpipe? I was thinking about cutting the standpipe about 6''-12" off the ground, adding a Y, and then adding the cut section of the standpipe back on.
What do you think?
Cacher_Chick
Test, Don't Guess!
The sink and washer standpipe must each have their own p-trap, and the traps must be vented. If you are in the U.S., the traps must be above the floor.
quote; What do you think?
It is NOT what we think, which you don't want to hear, but rather what you SHOULD do, namely, cut the sink drain into a drain line, and install a proper drain and vent. Probably NOT a DIY project.
graemew
Alberta, Canada
Standpipe
What would be the problem if I installed a Wye at the base of the standpipe? The washbasin has it's own P-trap, and the drain will be vented the same way that the washing machine drain is.
What would be the best way to install a Wye in a 2" copper standpipe anyway? I can't find any copper Wyes that size. The best that I can see is to go standpipe, rubber union, pipe, Wye, pipe, rubber union, standpipe. Not exactly the tidiest looking add-on then.
