Wall radiator valve problem
Discussion in 'HVAC Heating & Cooling' started by j3a3, Dec 28, 2009.
  1. j3a3
    j3a3 New Member
    Dec 28, 2009
    I have a 6ft radiator recessed in in the wall of my basement. It is not cast iron but the type with fins. On one side vertically leading to the radiator is a shut off valve then a spigot then another shutoff valve. (The spigot is in between the 2 shutoffs). I would like to replace the whole setup because it is very old and leaking. Should I replace it the same way or is there a better way using a bleeder type fitting or something similiar.
Similar Threads: Wall radiator
HVAC Heating & Cooling PTAC v. Through the Wall AC + Radiator? Jun 4, 2013
HVAC Heating & Cooling Window AC into through wall ? Apr 8, 2015
HVAC Heating & Cooling LOUD DRIPPING - A/C condensation drain behind the wall Jun 28, 2013
HVAC Heating & Cooling GE Wall units.. no more heat pumps? Nov 14, 2012
HVAC Heating & Cooling wall cap considerations for range hood Oct 30, 2012
