Vessel sink and faucet question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Dom Z, Jul 31, 2009.
  1. Dom Z
    Dom Z New Member
    Jul 31, 2009
    Remodeling my house
    Northern New Jersey
    I'm ordering a vessel sink the is 17" dia. by 6.5" deep.
    The faucet I'm ordering (Moen) is 12" high.
    Will this faucet work well with this vessel sink?
  2. hj
    faucet
    Where is the on/off handle? It makes no difference how tall the faucet is if the handle is behind the sink.
  4. Dom Z
    Dom Z New Member
    Jul 31, 2009
    Remodeling my house
    Northern New Jersey
    It's a single lever on the top of the faucet.
  5. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    Can't give a definitive answer without a cut sheet on the snk and faucet. Some vessel sinks sit entirely on top of the counter while some are set in 1/2 to 1 inch.
  6. jadnashua
    One thing that can happen is dependent on where the flow hits the bowl and how high your water pressure is. Get it wrong, and it could go down one side of the bowl and right across the bottom onto you.
  7. hj
    faucet
    If the handle is on top, and assuming the spout is also near the top, then why wouldn't the faucet work with the sink? Why did you ask the question?
  8. Dom Z
    Dom Z New Member
    Jul 31, 2009
    Remodeling my house
    Northern New Jersey
    Because my wife told me to.
    She seems to not trust my judgment on this and wanted a pro's view.
  9. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    You also need to make sure the aerator clears the top of the bowl. You don't want to fill the bowl and have the aerator under the water. I believe the industry standard clearance wanted is 1".
  10. hj
    faucet
    Just like a wife. The next thing she will do is expect you to read the directions when you install it. The only two things which would make it inappropriate would be if either the spout or handle hit or was obstructed by the sink rim. The handle is not a problem, so as long as the spout is higher than the sink it will work.
Similar Threads: Vessel sink
Plumbing Forum, Professional & DIY Advice Stone vessel sink drain problem Dec 2, 2016
Plumbing Forum, Professional & DIY Advice Vessel sink issue Sep 5, 2016
Plumbing Forum, Professional & DIY Advice Supply Lines to Vessel Sink Too Short Nov 15, 2015
Plumbing Forum, Professional & DIY Advice Vessel sink size question Nov 23, 2013
Plumbing Forum, Professional & DIY Advice Semi-recessed vessel sink - with overflow? Milforde Semi-Recessed Porcelain Sink Nov 25, 2012
