Venting toilet
Discussion in 'Remodel Forum & Blog' started by Rixtram, Aug 10, 2005.
  1. Rixtram
    Rixtram New Member
    Aug 10, 2005
    I have moved my upstairs bathroom across to hall. When it was time to put the 3" vent pipe through the roof I ran into trouble. I could cut through the double sill at the corner of the wall were the roof meets or cut through the rafter. I dont like my options. Can I run the vent pipe off the side of the house?
  2. plumguy
    plumguy New Member
    Jul 15, 2005
    MA
    Here you can't without permission from the inspector.
  4. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    if you have ceiling joist cut out the double plate. run the pipe thru the roof then install a long nail plate across the cut. the exterior plywood sheathing and the joists will keep it from moving. if its a vaulted ceiling you'd have to check if you have a weight bearing ridge before cutting.
    post a pic or give more info.
Similar Threads: Venting toilet
Remodel Forum & Blog Bathroom remodel with wall hung toilet. Need advice on plumbing and venting. Mar 10, 2014
Remodel Forum & Blog Shower and Toilet Venting Question Jan 2, 2012
Remodel Forum & Blog venting a new bathroom (toilet) Jul 1, 2007
Remodel Forum & Blog Venting sink and shower on saniflo ?'s Feb 6, 2017
Remodel Forum & Blog Venting a saniswift pump... Nov 21, 2016
