Valve leak at pressure test
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jonwarner4, Aug 25, 2008.
  1. jonwarner4
    jonwarner4 New Member
    Aug 14, 2008
    teacher
    upstate ny
    I'm doing the final connections on a tub. I have sweated together hot and cold water valves to the filler stem, although water lines are not yet connected. To check progress I closed the valves and literally put my mouth over the stem and did a rudimentary air pressure check.
    I heard a hissing of passing air, and it appears the leak is out of the bottom of the hot water valve. When I use my hand to block the fitting where supply will connect, the system is at least tight to what ever air pressure I can supply. This is a brand new Kohler K-300 system, so I'm surprised.
    Any ideas? Is this just a tightening of a nut on top of the valve? Could I have damaged anything inside while sweating connections?
    Help is greatly appreciated.
    Jon
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Its hard to say.
    If it's one of the Kohler valves that uses rubber seat cups similar to Delta there may not heve been enough pressur to set the seat.
    I'd turn on the water and see what happens.
  4. jonwarner4
    Aug 14, 2008
    teacher
    upstate ny
    ceramic disc valves
    Thanks Redwood. Literature I find says it uses "ceramic disc valves" - is this in lieu of any rubber rings / seat cups?
  5. Redwood
    Dec 15, 2007
    Service Plumber
    Try the water test
Similar Threads: Valve leak
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Replaced Delta 2 handle faucet cartridges now there is small leak from valve stem Oct 30, 2016
Plumbing Forum, Professional & DIY Advice Accor Flowtite Valves...leak...totally clueless new homeowner Oct 28, 2016
Plumbing Forum, Professional & DIY Advice Valve Stem Leak. Should I be worried? Sep 22, 2016
Plumbing Forum, Professional & DIY Advice Two leaks in Hardie Irrigation Valves Aug 10, 2016
