Utility sink and washing machine
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by n2learning, Mar 23, 2010.
  1. n2learning
    n2learning New Member
    Mar 30, 2009
    Missouri
    Can a utility sink and washer share the same 2" drain?
    Both fixtures are vented.
    The utility sink and washer are on adjacent walls, the washer hose does not drain into the utility sink. The washer hose will drain into a 2" standpipe. I was hoping I could tie into the utility drain after the washer p trap.
    (I can post pics if need be)
    Thanks,
    DK
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    If you do what you propose you will end up with a line thats not vented, if both lines are vented a 2in. line is fine.
  4. n2learning
    Mar 30, 2009
    Missouri
    This is in a basement. Utility sink wtih vent.
    [​IMG]
    Picture showing the stand up pipe and the vent. Obviously nothing is glued yet....and the vent will be extended of course.
    [​IMG]
    The drain will then connect to the main drain. Am I good to go with the washer once all fittings are cemented?
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Not quite.
    Think about how gravity works here- the trap has to be ABOVE the horizontal drain from the sink.
    Also, a sani-tee is not approved for use on a horizontal line. Some areas will accept it for the vent, but not the drain. Use a wye and 1/8th bend combination instead.
    I would prefer to have the washer standpipe and trap flat against the wall. Check out Terry's picture for an example-
    [​IMG]
  6. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    You'll want to install the vent and p-trap on a seperate branch. So, in this case, the vent willl be in the same wall as the p-trap.
  7. hj
    The pictures I see do NOT show any vents, or at least none where they should be.
  8. n2learning
    Mar 30, 2009
    Missouri
    How about this? I don't have the vent line in but you can see where it would go. This is just a prototype, I'll probably tighten it up.
    [​IMG]
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Sani-tee transitions horizontal to vertical
    Wye and 1/8 bend transitions vertical to horizontal
    Lose the extra length between the wye and 1/8 bend too.
  10. hj
    You are doing it the hard way. Install a combination Y-1/8 bend next to where the trap will be. Glue a street 2x1 1/2 x 1 1/2 sanitary tee into that, and the trap into the side of the tee. The vents only have to be 1 1/2".
  11. n2learning
    Mar 30, 2009
    Missouri
    Thanks for the illustration, it helps. I had to do an image search for 'wye and 1/8 bend'; that's a fitting I haven't bought.
    Is it okay if the vent is 2" or should it really be 1 1/2"?
  12. hj
    It does NOT have to be 1 1/2", but it can be. There is no problem with making vents larger than necessary, it just costs more.
  13. n2learning
    Mar 30, 2009
    Missouri
    How about this?
    (The 2X4 will be gone once I strap the pipes in place.)
    Also, is there a minimum or maximum height requirement for the stand-pipe?
    [​IMG]
Similar Threads: Utility sink
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Basement utility sink Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Washing Machine with Utility Sink - 1-1/2" Drain! Dec 6, 2016
Plumbing Forum, Professional & DIY Advice Need help on planning washer & utility sink setup Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Need help installing utility sink. Sep 7, 2016
