Uponor AquaPEX size 1/2 vs 3/4
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by petepdx, Nov 15, 2013.
  1. petepdx
    petepdx Member
    Jun 23, 2006
    Portland, OR USA
    Getting ready to change the galvanized with AquaPEX in my urban 1950's rancher with full basement (easy access to everything for a change!!!)
    I'm going to use 1" up to a manifold, but on the other side I can't decide if I should use 1/2 or 3/4 ?
    The coming summer I'll replace the line from the meter with 1" as well.
    The service meter will more then likely stay 3/4" the city wants over a $1,000 to change it from 3/4" to 1", but the option will be there.
    -pete ready to order the red&blue ...
  2. DaveHo
    DaveHo Member
    Mar 12, 2010
    SE PA
    Home run system? Unless you have some gigantic tub to fill, 1/2" is plenty big save for maybe outdoor hose bibs. You might even want to consider going with 3/8" for some of the hots if it's a long run. It'll cut down on the wait for hot water.
  4. jadnashua
    Many fixtures in the house are flow restricted. Those that typically aren't include: washing machine, tub filler, hose bibs, laundry sink. A dedicated shower, if you've got more than one head, can use a larger supply line as well. If the run is long, a larger pipe may be called for.
  5. petepdx
    petepdx Member
    Jun 23, 2006
    Portland, OR USA
    Screwed up my search of the forum, looks like this question has been asked quite a few times
    Sorry for the repeat ...
    -pete
  6. hj
    Your 1" PEX main line will only be slightly larger than a 3/4" copper or galvanized line, so the 3/4" meter will be adequate.
  7. Terry
    Aug 17, 2004
    The 3/4" meter is fine, I would mate that with a 1" poly or 1-1/4" PEX line. Assuming this is a three bath home.
  8. petepdx
    petepdx Member
    Jun 23, 2006
    Portland, OR USA
    Thanks Terry. I've received pretty much the same. The house is 2bath. For the main distribution within the house I'm going to use 1" Uponor/Auqapex. Being a tool nut, I bought the Milwaukee M12, I have another house that will need re-plumbing so the two gave me justification :), It limits me to 1". For the line to the meter, I'll go with PEX 1-1/4" if I can rent a tool, if not I'll go as you recommend 1" PE.
    Tossing the idea to just use a couple small 3-4 outlet manifolds and using tees for the outside hose bibs. The curse and blessing of so many options
    -pete
    Again thanks,
    -pete
    (*) wish
Similar Threads: Uponor AquaPEX
Plumbing Forum, Professional & DIY Advice Uponor Aquapex Tubing and Ultraviolet Light Sep 18, 2012
Plumbing Forum, Professional & DIY Advice Re-plumbing the house with Uponor Aquapex, have a couple of questions Jul 31, 2012
Plumbing Forum, Professional & DIY Advice Red/Blue AquaPex (Wirsbo/Uponor) Scratch Question. Oct 15, 2006
Plumbing Forum, Professional & DIY Advice Uponor PEX with non-ProPEX fittings Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Replace Uponor Tee Jun 6, 2015
