HS345
- Messages
- 7
- Reaction score
- 0
- Points
- 0
Hello all,
I have a well system with a submersible pump, and a tank of some sort.
Recently, I have been hearing a noise from the tank toward the end of the pump cycle. It sounds like water trickling, or squirting (for lack of a better term). As soon as the pump stops, the noise stops. I haven't noticed any loss of pressure, or air at the faucets.
I am not sure if that is enough info, though I assume it is probably not.
I would appreciate any advice you can give, so thanks in advance.
BTW, I am a regular over at the John Bridge forums, not sure is that helps, or hurts.
Not sure what the image posting rules are, if I am outta line lemme know.
