Type of check valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by alternety, Oct 3, 2006.
  1. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    I am specifying some check valves in my new water system (well source). They are used to keep water from moving backwards through the centrifigul pressure pump and from flowing backwards through a filter that has its own pressure tank on the filtred side.
    I would appreciate input on wheather to use swing checks or spring loaded checks.
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    There are spring loaded checks for that purpose.
  4. Rancher
    Rancher Guest
    Where is your centrifugal pump located?
    Rancher
  5. Hardt
    Hardt Member
    Nov 18, 2005
    Hawaii
    FWIW, I don't have any experience whatsoever in wells but my solar water system used a spring check valve and the rubber o-ring deteriorated to nothing and the spring probably was not at specs because of age. I had recurring problems trying to keep it working so I replaced it with a swing check valve and I don't see anything that can go bad with it... no spring, no rubber o-ring and don't see gravity going away anytime soon. :) It has worked flawlessly for the past 5-6 years.
  6. Cass
    Cass Plumber
    Nov 12, 2005
Similar Threads: Type check
Plumbing Forum, Professional & DIY Advice Least pressure drop check valve type? Nov 26, 2013
Plumbing Forum, Professional & DIY Advice Multiple types of sewer smells? Jun 28, 2016
Plumbing Forum, Professional & DIY Advice Thread types for water heater hoses Apr 11, 2016
Plumbing Forum, Professional & DIY Advice What type of diverter is this??? Please Help!!! Mar 19, 2016
Plumbing Forum, Professional & DIY Advice Moen Valve type and replacement trim Mar 11, 2016
