Tying 4"x4"x2" all-hub into existing stack
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Ed_S, Oct 11, 2007.
  1. Ed_S
    Ed_S New Member
    Oct 11, 2007
    I'm renovating my master bath and have a question on tying in a 4"x4"x2" all hub waste connection into the existing stack. My intent is to leave the remaining existing rough plumbing as-is but if I have to remove, then the new will trace the same route as the existing. Since I'm converting the old tub area into a single shower, I have to change out the 1 1/2" p-trap into a 2". Where I'm confused is the tie-in of the new PVC 4"x4"x2" into the existing cast iron vent stack. I know I have to use the reinforced hub couplings since the connection is above ground. Given the diameter of the 4" hub is wider than the 4" cast iron, do I add a length of 4" pvc pipe into each of the 4" hub sections to create a better match of the pipes to be connected with the reinforced hub. I've attached a picture to give you my idea. To me, adding the additional 4" wide section make the transition more clean. Thoughts?
    http://i114.photobucket.com/albums/n245/esuggs/ShowerStack.jpg
    [​IMG]
    Santee
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    They make a PVC to CI no hub adapters you will need a short piece of PVC
    pipe between tee & CI.Use no hub couplings.
  4. MG
    MG New Member
    Jun 29, 2005
    Illinois - Near St. Louis
    Better make sure you support that stack on both ends!
  5. Ed_S
    Ed_S New Member
    Oct 11, 2007
    Good point, I'll have the walls open. We're in a single story house with good attic access. Perhaps I should just replace everything down to the waste line, minimizing the modifications.
  6. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Good idea to replace it all.
Similar Threads: Tying 4x4x2
Plumbing Forum, Professional & DIY Advice Tying in - in a tight space Nov 18, 2015
Plumbing Forum, Professional & DIY Advice How to emptying water from drain pan under washing machine? Oct 10, 2015
Plumbing Forum, Professional & DIY Advice Tying in Dehumidifier to Crawl Space Drain Pipe Sep 12, 2015
Plumbing Forum, Professional & DIY Advice Rule for tying in a drain after a water closet? Sep 4, 2015
Plumbing Forum, Professional & DIY Advice Tying Tub & Toilet directly into main stack Aug 7, 2015
