Two pumps one irrigation system
Greenmonster123
Active Member
Sag Harbor, New York
working on plans for large irrigation system. Currently there are two 3hp 40 gpm submersible pumps each making 45-50 gpm @ 60 lbs. This may not be enough water to irrigate the whole property in the desired amount of time. We were thinking of swapping out one of the 3hp pumps for a 5hp 75gpm that will make about 95gpm.
My question is how to control these and how to set the switches? I was thinking CSVs with overlapping spreads on the switches but which should cut in first the 3 hp or the 5 hp.
Thanks
Boycedrilling
Royal City, WA
You can make this as simple or as complicated as you want. Do you want the same pump to always be the lead pump? Or do you want the lead pump and lag pump to alternate?
It can be as simple as setting the pressure switch2-5 psi lower on the lag pump, to as complex as you can afford.
If I'm not alternating the pumps, the smaller volume pump is usually the lead pump.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
I agree with Boyce. I usually lead with the smallest pump.
3HP with 60/80 switch and CSV at 70.
5HP with 50/70 switch and CSV at 60.
One 86 gallon tank if pumps are close together. A 44 gallon tank at each pump if the wells are 50' or 2 miles apart.
