Tub install queston.
Discussion in 'Shower & Bathtub Forum & Blog' started by JT, Dec 13, 2012.
  1. JT
    JT New Member
    Dec 13, 2012
    Los Angeles
    Hello. I have learned so much from reading the threads on this site but I have run into a slight problem with a tub install. I have searched and found several topics with the same issue.
    I have a Bootz porcelain over steel tub from HD. The tub has a stryofoam base. When the tub rest on it's base it is stable but is no where near level. Bathroom floor is solid concrete and level. When leveled with a stringer the stryofoam base on the srtinger side is about a 1/2" off the ground but does touch on the apron side. This creates lots of flex and squeaks.
    Should I just scrape off the stryofoam and motar bed it? When I shimmed it it seems like the stryofoam just compressed around the shims.
    Thank you.
  2. hj
    My personal opinion is that I would NEVER spend time installing a steel tub, unless the customer insisted on it, but that is just my bias. The styrofoam must have been "damaged" because it should set on the floor and support the tub. Low expansion spray foam under the styrofoam should stabilize the tub.
  4. JT
    JT New Member
    Dec 13, 2012
    Los Angeles
    The styrofoam looks to be intact and level with the tub with only slight damage to the corner that broke off and where the shims compressed it. It just looks like the styrofoam is not thick enough to make contact with the floor when the tub is level and rest on the stringer and apron. At first I thought the some styrofoam was touching the floor but actually there is a gap under the whole bottom of the tub. The expansion foam sounds like a good idea but I have read that it will gradually compress over time. DSC00573.jpg
  5. Terry
    Aug 17, 2004
    Most tubs don't touch the floor.
    That's why we use a stringer on the back wall, and shim as needed on the apron.
    A steel tub will flex. If you don't want a flexing tub, then going cast iron is nice. Kohler makes really nice cast iron tubs.
    I've installed plenty of shower enclosures that had a foam base. It's better than no foam.
  6. JT
    JT New Member
    Dec 13, 2012
    Los Angeles
    I thought the tub was supposed to sit on the styrofoam bottom? Or some type of solid base? When I stand in the tub I can see the apron bulge out at least a 1/4".
  7. Terry
    Aug 17, 2004
    Hey...........I'm not saying Bootz is a quality tub.
  8. DBIprop
    DBIprop New Member
    Dec 13, 2012
    new jersey
    I would put a bed of structolite on subfloor and set the tub/styrofoam base into that while still using your stringer for level. Shim outer edge as needed.
  9. JT
    JT New Member
    Dec 13, 2012
    Los Angeles
    Terry I agree not a quality tub. It just has so much flex that I think I will go with DBIprop's advice and go with a structolite base. DBIprop do you recommend a barrier of poly between the structolite and styrofoam/tub? And maybe some poly or felt on the concrete subfloor?
  10. jadnashua
    The bond breaker will mean you could eventually remove the tub without excessive work...it wouldn't hurt.
  11. josephmcullen
    josephmcullen Joseph Cullen
    Dec 19, 2012
    Home Designer
    5831 Bonnie St Pahrump, NV 89048
    Try to install walk in bath tubs, they are very easy to install and very easy to access for elders or for the handicapped members. If you find trouble in installing tubs, you can install it by professional agent.
Similar Threads: install queston
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
Shower & Bathtub Forum & Blog Installing a Panasonic bathroom exhaust fan in a condo Feb 9, 2017
Shower & Bathtub Forum & Blog Under mount tub install mystery Jan 30, 2017
Shower & Bathtub Forum & Blog Shower installation over a sump pit in a concrete floor with radiant heat Jan 1, 2017
Shower & Bathtub Forum & Blog Just installed acrylic Delta Tub and 3 piece surround (attach to studs type) Dec 11, 2016
