Time to update the progress. It seems up here in North Idaho getting a well rehabilitated is not easy unless you do it yourself. I contacted Northwest Hydrofracturing 8-10 times without a return call, even on their website. When they did return the call, the job was contracted to be done. 4 well drillers that advertise Well Rehabilitation would not do it. They just wanted to drill another or deepen the one I have.
I finally went with the Water Recovery Services that used the Aqua-Freed process. They were the only ones that I could get to look at it.
They videoed the well, pulled the liner, scrubbed the well, screens and whatever else. Then they installed the liner, a new pump, wiring and controller at my request. The initial results from them were that it was producing 5 gpm. We ran it at 15 gpm for 14 minutes before it kicked off "dry" . That calculates to 3.5 times what we did have. Some off the CO2 may still be frozen and we could improve that regeneration rate.
I know that I was advised against using this method by members here. I simply had no other choice but to do it myself. Not an option I wanted. As to the effectiveness of the process, I cannot speak. The company was great to deal with. They were prompt. Now I have 3.5 times more water than I did before. Even if it was just the cleaning of the screens by them I would be happy with the service and results.
I installed the Cycle Sensor and just need to tweak the run dry reset time.
2 questions.
1. With such a shallow well and not much reserve in the well itself, what should I set the reset time for 15 minutes, 30 minutes?
2. Would it be better to "throttle back" the inflow into the cistern to keep the well pump running longer between running dry periods?
If I throttle it back to 4 gpm it would almost run constantly when needed. Where is the sweet spot for running the pump?
BTW. With the differential valve in the cistern I can set the amount of draw down before the pump is needed. If I let it draw down 1000 gals, It would take 5 hours to refill at the current regeneration rate.
Thank you everyone for helping with this. I wish I had more choices but I am glad it worked out for me.
Kent
