DIYFixer
Long time lurker, first time poster. This is an excellent site!
I'm in the process of a master bath remodel. Removing tub/shower and replacing with walk in shower. I pulled a permit, so will be getting all work inspected. I'm in California, CPC applies.
The tub drain was 1.5" so I'll be running new 2". The shower trap arm will run from the center of the new shower to the existing vent stack, connecting with a 2" san tee. Below the san tee is a 90 elbow connecting to the waste line. Because the change in direction from trap arm to waste line in > 135 degrees, I plan to install a 2" cleanout in the vent line. The cleanout will be in the wall cavity, accessible from a panel in the adjoining room. Do you see any code compliance problems with this plan?
The shower drain will tie into the existing lav branch. I plan to replace the existing 2x2x1.5 long sweep tee with a 2x2x2. I plan to install a 2" test tee just downstream of the long sweep tee, so I can install a test ball for the pressure test. Does that sound reasonable?
