Toto Vespin Big installation problem
Discussion in 'Toilet Forum discussions' started by FJK, Aug 4, 2011.
  1. FJK
    FJK New Member
    Jun 15, 2005
    Illinois
    I need some creative thinking here, I really screwed myself on this one.
    Total bath remodel, walls are painted, tile is in ( including baseboard tile next to the floor). So, I'm installing a Toto Vespin toilet, same as I installed in another bathroom. This toilet uses the modular drain system, so I'm concentrating on building up the flange, etc. As I mock up the modular drain, I notice that the water supply line is only 4" off the center line of the drain. On my other Vespin installation, the water supply line was 9" off the centerline of the drain. The toilet is not going to fit. Now what???
    My specific model is a CST474 CEF (G) and the Toto installation instructions say a min distance for the water line is 8". The same instructions also say for a CST 794 toilet the min distance to the water line is 4".
    So, do I try to exchance the toilet for a CST 794, but was is a CST 794?
    Or, is there some creative way to 90 degree pipe out of the wall and then be able to install a shutoff valve & run the water supply line as normal? Please tell me an alternative to knocking out the drywall.
    Thanks, FJK
  2. Terry
    Aug 17, 2004
    You can 90 over if it's copper.
    Or use a Dahl stop for the Toto
    Normally the Vespin II needs 6" to the left of center.
    [​IMG]
    [​IMG]
  4. FJK
    FJK New Member
    Jun 15, 2005
    Illinois
    Yes, I have 1/2 copper. So are you saying 90 over using a sweated fitting or use a Dahl 90 valve as you have shown (I assume that is what you are calling a Dahl stop. The Dahl stop, where can I get one, a lumbing supply house? This might save the day as long as it can hug the wall & not protrude more than 2". That's the clearance I have with my other Vespin II.
  5. Terry
    Aug 17, 2004
    You can slightly bury the angle stop in the wall sometimes, or just solder on a 90 el.
Similar Threads: Toto Vespin
Toilet Forum discussions Toto Aquia II (2 piece) vs Toto Vespin II (2 piece) Mar 15, 2017
Toilet Forum discussions Vespin II and Toto parts Sep 19, 2016
Toilet Forum discussions Toto Vespin II 1.0 gpf or 1.28 gpf? Jun 14, 2016
Toilet Forum discussions Toto Vespin vs what plumber knows Aug 17, 2015
Toilet Forum discussions Broke off a flush valve hook - Toto Vespin Aug 20, 2014
