Toto Neorest 500 vs. 550 vs. 600 comparison?
Discussion in 'Toilet Forum discussions' started by Rufus17, Mar 2, 2011.
  1. Rufus17
    Rufus17 New Member
    Mar 2, 2011
    Denver, CO
    I am going to be purchasing a Toto Neorest, but was a bit uncertain of tradeoffs?
    The Neorest 500 seems to have almost everything necessary, for about $2,690. The Neorest 550 is priced at $4,204 and the Neorest 600 is $4,372
    What do you get for the extra $1,682? Am I missing something or is the 500 have almost everything (except a nightlight and different styling)
    Thanks so much!
  2. Terry
    Aug 17, 2004
    My favorite now is the 550, it has the side panels that allow the hiding of the water supply.
    The 500 and the 600 have exposed water supply.
    The 550 being a Watersense dual flush, it also gets a rebate if available in your area.
    It also has a night light.
    [​IMG]
  4. zelpheri
    zelpheri New Member
    Apr 18, 2012
    Frisco, CA
    Toto Neorest 500/550/600
    I bought a few Neorest toilets.
    I am looking at installing these in a house I just bought.
    I've read the forums here and have some questions:
    - do I need to purchase the install kits to be able to install the toilets or is everything I need already in the box?
    - how many amps do the power outlets require? 15 or more ?
    - do I need to change any piping inside the wall?
    http://www.totousa.com/Portals/0/BrochureDownloads/neo-compare.pdf
  5. Terry
    Aug 17, 2004
    The Neorest 500 needs 1281 watts
    The Neorest 550 needs 1284 watts
    The Neorest 600 needs 1288 watts
    They all come with the floor adapter and a water supply shutoff.
    The water supply is for a 1/2" pipe from the wall; this works best if you have 1/2" copper lines.
    PEX inside diameter is smaller and may need give enough volume.
    What doesn't come in the box, is the wax for the flange and the closet bolts to attach the adapter to the floor flange.
    A floor adapter for the 600
    [​IMG]
  6. agie
    agie New Member
    Mar 21, 2012
    SE CT
    A dedicated 20 amp circuit with GFCI receptacle will be the right choice.
  7. jadnashua
    A dedicated 15A CB is fine...15A = 1800W, so even if you took 80%, you'd still be fine at 15A. Probably not a good idea to share that CB with anything else unless it was hard-wired and a small load, though.
Similar Threads: Toto Neorest
Toilet Forum discussions Toto Neorest 550 - Sensor Issues Wednesday at 3:02 AM
Toilet Forum discussions Is the TOTO Neorest 550 MS980CMG worth $1000 more than TOTO G500 MS970CEMFG Dec 24, 2015
Toilet Forum discussions Toto Neorest MS950CG Front Mounting Block Jul 26, 2015
Toilet Forum discussions Toto Neorest toilet seat cleaning Jun 19, 2015
Toilet Forum discussions Toto Neorest 600 Washlet Failure Jun 12, 2015
