I am brand new to these forums, but have found these forums quite helpful. At times, it seems that there is more information than I need or can assimillate in a single read.
My Question/Problem involves exchanging (?) Toto toilets to resolve several problems.
Problem 1 - Need performance flushing better than the Toto which has a designation inside the tank of ST706. It looks like a drake tank to me based on size/dimensions; but it does not perform well in flushing which is my major problem. Based on what I am able to gather on the forum(s), drake CST 744S should work well for me with the pressure flush IF it will fit in the same space occupied by the 706 (which is a very snug fit agains the back wall). Will it fit?
Problem/Question 2 - Will the Elongated CST 744S fit in the in the same space as the 706 (given that the protrusion from the wall is a bit more; which I can spare so long as the space to wall is the same as the current tank, as it appears to be from the specs)
Question 3 - is there anythng that can be used (beside the seat in the exchange? and question 3.5, where does one "recycle" toilets?
It may all sound simple and obvious - but I need some reassurance that I am not trying to do something that won't work or make sense.
Thanks to any and all for any feedback.
