Toto Aquia and Unifit?
nickh
Is the Aquia compatible with Toto's Unifit adapter? My rough-in is 10" and I'd hate to change it...
Also, is there a PDF installation manual available for the Aquia? I've seen some for other Toto toilets, but not the Aquia. I'm mostly interested in how the toilet is screwed to the floor - I assume it doesn't use only the flange bolts?
Aquia rough-in
The Aquia uses it's own adapter and is not compatable with the Unifit.
TOTO does make a 10" bowl though.
10" Rough, CST412MF.10
12" Rough, CST412MF
nickh
Thanks, Terry!
Ah, I see. I was wondering how those side-mounting bolts worked...
One other thing - I have an odd situation in that I have some radiant tubing running along side the toilet, within inches of the toilet flange.
Can you tell me the location of the plastic blocks you mention, in relation to the drain/flange?
I live in Seattle - do you have these toilets in stock? If not, how long to get them?
