Toilets that sit flush to the wall
Discussion in 'Toilet Forum discussions' started by bookssy, Jan 12, 2011.
  1. bookssy
    bookssy New Member
    Jan 12, 2011
    brooklyn, ny
    I am interested in a toilet with a bottom outlet 12" rough-in that sits right flush to the wall. The Duravit Happy D http://www.duravit.us/products/series/happy-d./toilets--c-toilets_useo6q3rqe.html or Duravit US Toilets one piece http://www.duravit.us/products/series/us-toilets/toilets/one-piece-toilet--016301_toilets_93538_useo6q3ru8.html
    The Kohler Saile http://www.us.kohler.com/onlinecatalog/detail.jsp?from=thumb&frm=&module=Toilets&item=13150202&prod_num=3564&section=2&category=13 or Persuade look like they might fit the bill, but the pictures don't really show them at the right angle. I really really hate the dirt catcher behind the bowl under the tank. It's backbreaking to get at and it gets really hairy and disgusting if you ignore it.
    Can anyone suggest some models for me? Thanks in advance!
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Ignore the promotional photos when it comes to real world installations. The only way you will have a toilet sit flush perfectly against the wall is if you have a very competent plumber who changes the rough-in to suit the exact model toilet you purchase, or if you install a caroma unifit model. And the only way you are going to minimize crud building up behind the toilet is to purchase a one piece skirted model.
  4. jadnashua
    All toilets(except wall-hung) are designed to NOT sit against the wall. Depending on the rough in, it could.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If you think that even if you find a toilet that sets flush against wall you won't have a cleaning problem, you'll be in for a disappointment. Actually, with some space it is easier to clean. None of the toilets you mention would be worth bringing home, IMHO. The first Duravit is a wall mount and would be totally unsuited. Kohler is notorious for not having product support after a few years, and many of their parts are available only from the factory at a very high price. Some parts have been known to cost as much as a good quality toilet.
  6. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    ANY wallmount toilet will let you clean under the floor easily.
    All hung toilets are good. Many are available. I have these. I also have a Happy D, and we are happy.
  7. hj
    The only way a floor mount tank type toilet would fit "tight to the wall" would be if the plumber knew EXACTLY how far the opening had to be from the finished wall, AND also knew how thick the finished wall would be from the framing. I would NEVER attempt to install the pipe that way, and hope it would all come out properly in the end, because if it did NOT, and the wall was thicker than specified, (which is OFTEN the case), I might be the one who had to pay to break the floor and move the pipe, then retile the floor or bathroom.
  8. Gary Swart
    Sep 1, 2004
    Yakima WA
    What geniescience failed to mention us wall hung toilets do not flush through the floor. They require a 6" wall with the drain inside the wall, and special mounting hardware.
  9. hj
    I guess he felt that was just a "minor" technicality, but one that adds hundreds of dollars to a new installation, and maybe THOUSANDS to an existing one.
  10. Gary Swart
    Sep 1, 2004
    Yakima WA
    You might be interested in the Toto Ultramax ii. If you Google "Toto Ultramaxii flush" you can find a U Tuba video and brief description of the flushing of the Ultramax. The Ultramax ii is a one piece unit which makes for the easy cleaning you are concerned with. As previously discussed, any toilet the set tight against the wall will still have a small, impossible to clean gap. Better to have the skirt with some space to the wall that at least can be cleaned. Of course, the first concern of any toilet is the quality of the flush. I think the video will show the Ultramax ii qualifies on that requirement. The model that seems to be a very good seller is the MS604114CEFG. It will qualify for a rebate if your area offer them.
Similar Threads: Toilets flush
Toilet Forum discussions Multiple toilets flushing automatically Apr 25, 2016
Toilet Forum discussions Up Flush Toilets Apr 21, 2015
Toilet Forum discussions Delta Toilets with FlushIQ Nov 4, 2014
Toilet Forum discussions Help! Sewer smell coming from toilet every time its flushed - all toilets in house Aug 22, 2013
Toilet Forum discussions Toilets that flush with your mobil phone Apr 1, 2013
