Toilet will be a bit tight
Discussion in 'Remodel Forum & Blog' started by Ian Gills, Sep 20, 2009.
  1. Ian Gills
    Jul 24, 2007
    USA
    My basement toilet will be darn close to the wall when fitted.
    Before I build the wall...
    what is the clearance needed for a toilet again?
    Thanks.
  2. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    15" either side from the center of the bowl and 21" from the front
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Really? That's all? So I could put a toilet in a 2'-6" x 2'-9" room? Neat! Coat closet, move over.. :)
  5. Ian Gills
    Jul 24, 2007
    USA
    Forget the garage, make it into a second bathroom!
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Ian, I'm not sure I understand your question. If you are talking rough-in distance, that's finished wall to the center of the drain, the actual distance needed will depend on the toilet you use. I assume you are going to us an AS toilet, so you will need to see the spec sheet and find out what the model you are going to install really requires. I think AS is similar to other brands, including Toto, in that the actual space needed is usually somewhat less than the rough-in size listed for the toilet. Of course, a toilet listed as a 12" RI will always fit a 12" space, but there will be some space between the toilet and wall.
    On the other hand, if you are talking about side clearance, then it's 15" center of toilet to wall.
  7. Terry
    Aug 17, 2004
    15" from center to next object, 30"
    24" in front of bowl
    Length of bowl is about 28" plus the 24" gives you about 4'4"
  8. Ian Gills
    Jul 24, 2007
    USA
    Thanks for all the very useful responses. It was the side dimensions I was after.
    I am roughing in the toilet supply stub 7 inches off center and 7 inches off the floor.
    Since this is just the dark, dirty, damp basement, I will probably just go for a cheap, nothing special Toto Drake hidden out of view....the AS Cadet 3 will retain pride of place in the master.
    I am tempted to go for a one piece after hearing all the advantages.
    How far does the 12 inch Drake extend back? My drain is currently 12 inches from the studs (11.5 inches with the drywall up).
  9. Terry
    Aug 17, 2004
    The Drake needs 11" from finished wall.
    I prefer the Sanagloss version.
    The one-piece comes with the seat, and then the tank is molded to the bowl.
    Pull it from the box and stick it on the wax.
Similar Threads: Toilet tight
Remodel Forum & Blog Toilet pipe not 100% vertical -- how "out" can it be? Feb 12, 2017
Remodel Forum & Blog Toilet plumbing in wall? Feb 18, 2016
Remodel Forum & Blog How to Install Back to Back Wall Hung Toilets on 1962 Rough-in Stack Aug 30, 2015
Remodel Forum & Blog 10" Rough In Toilet Jun 30, 2015
Remodel Forum & Blog Toto Soirée toilet May 12, 2015
