Toilet Wax Ring Installation Question
Discussion in 'Toilet Forum discussions' started by jk60, Nov 29, 2005.
  1. jk60
    jk60 Engineer
    Nov 20, 2005
    Engineer
    San Francisco
    I've just ordered a Toto Ultramax toilet to replace an older Kohler in my bathroom. I have an installation question dealing with which wax ring to use. Should I use one with a plastic horn or just straight wax? The drain pipe diameter is 4-inches and the Kohler was originally installed using a wax ring with a plastic horn. The drain pipe flange sits slightly above the finished floor so I know that one wax ring will do the job.
    Thank you,
    Jerry
  2. Terry
    Aug 17, 2004
    One wax ring will do if the flange is slightly higher than the floor.
    Either one could work, though if the toilet rocks on the plastic horn, I would have the hornless one ready to go.
  4. jk60
    jk60 Engineer
    Nov 20, 2005
    Engineer
    San Francisco
    Thank you for your advice. Having two on hand will certainly save a trip to the store. I have just one more question with regard to the wax rings with a horn. Are there different sizes (diameter) for the bottom of the horn or is there only one standard size? The one that was installed there previously has a diameter of about 2.75-inches.
    Thank you,
    Jerry
  5. Terry
    Aug 17, 2004
    They seem pretty standard to me.
Similar Threads: Toilet Ring
Toilet Forum discussions Toilet Ring Leaking in Rental House Jan 3, 2017
Toilet Forum discussions Two toilet rings, one hidden Dec 23, 2015
Toilet Forum discussions part of wax ring fell down toilet's main pipe Apr 16, 2015
Toilet Forum discussions Crane Walsan wall-mount toilets ...Considering replacing 3 Mar 29, 2015
Toilet Forum discussions Will a sani-seal (waxless) ring work if my toilet has indentations? (pic) Feb 19, 2015
