Toilet water in bowl slowly drains minutes after flushing has completed
Discussion in 'Toilet Forum discussions' started by Voyzey, Aug 5, 2005.
  1. Voyzey
    Voyzey New Member
    Aug 5, 2005
    The water in my toilet bowl drops very slowly minutes after a flush has been completed. The water in the bowl won't empty completely but it does drop considerably lower than right after it completed flushing. It has me a little puzzled because there isn’t any leak anywhere around the bowl or tank and the water in the bowl does eventually stop dropping after a while. I installed a new FluidMaster Flush Valve & Flapper over the weekend but that didn't fix the problem.
    How do I get the water in the bowl to stay at the height it's at right after completing a flush? Is this a DWV problem? A couple of years ago I had a bird caught in the pipe. It eventually turned up inside a toilet!!! My first experience with a clogged vent! :eek: Could a blocked vent be the cause of this problem again?
    Any help would be greatly appreciated. Thank you!
  2. Terry
    Aug 17, 2004
    [​IMG]
    Water in the bowl is based on the height of the bend of the trapway.
    Water will drain over the "dam" until it's even with the top.
    If the water is lower than that, it could indicate a leak or crack in the bowl.
  4. Voyzey
    Voyzey New Member
    Aug 5, 2005
    Follow-up question...
    Thank you for replying to me! If you don't mind me asking a couple more questions...do you have any insight as to where the leak could be? I don't have any water around the bowl on the floor. Is there a test I can perform to be certain it's a leak? I'm pretty sure the bowl filled higher and kept the water height years ago before I encountered this problem. Thank you!
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Toilet
    Make sure that the small refill tube is connected to the overflow pipe by using the metel clip. That keeps the refill tube above the top of the overflow pipe and by the time the toilet shuts off, the bowl should be up to its overflow point. A partially plugged sewer may cause water to lower in the bowl. also I have seen a sand hole in the china casting let water drain down. The toilet was several years old. I found it when I turned the bowl upside down. Was able to fill hole with an epoxy. Again,check the refill tube..........
  6. Voyzey
    Voyzey New Member
    Aug 5, 2005
    Follow-up...
    Thanks for your help! I checked the small refill tube and it's definitely connected to the overflow pipe correctly - just above the top of the overflow pipe line. Water still seems to be dropping after the flush has completed though. Looks like I'm relegated to removing the toilet and checking for leaks, huh?
  7. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Wat
    If you pull the toilet, turn it upside down and look for a pinhole like spot that might have a little rust streak near it. I've seen it twice. assumed that there was a thin spot in the china when it was cast because the toilet was a few years before this leak showed up.
  8. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    I had this issue, and was surprised by the fact that this toilet drained itself of every last drop of water in the bowl. The problem? A pressure assist bowl installed with a regular 6L flush tank...
  9. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    low water
    Is this toilet on a slab?
  10. slicey
    slicey New Member
    Aug 21, 2005
    "Make sure that the small refill tube is connected to the overflow pipe by using the metel clip. That keeps the refill tube above the top of the overflow pipe and.........."
    could you clarify.....in the above excerpt, do you mean the clip holds the refill tube in place so that, when the toilet is flushing, water from the refill tube is directed into the overflow tube? I'm clueless as to what purpose the refill tube serves. Would you explain using the good image from post #2
    thanks slicey
  11. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    I'll jump in here. The purpose of the refill tube is to "refill" the bowl after a flush. Without it, the water level in the bowl would be a bit lower than the maximum it could be (refer to Terry's graphic above) due to siphoning action during the flush. The fill valve directs most of its water into the tank, but a small part of it goes down the overflow tube and into the bowl to "top it off."
  12. slicey
    slicey New Member
    Aug 21, 2005
    thanks, SteveW, now i know.
  13. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    hair line crack in bowl??
    it might be an idea here to just go out and buy some
    green or blue food coloring and put some in the bowl
    to siphon out on the next flush.....
    let it sit for a day or so and eventually if their is a hiair line crack
    in the trap , it will leave you a line in the china to seee....
    if or when you take up the bowl to see what is going on with it....
    their can also be sometihing like a mop string caught on the trap
    wier of the toilet hanging down into the drain , this will make the toilet
    siphon down the its water...
    maybe you might want to just get a toilet auger and shake things
    up a little bit first....
    enjoy......
  14. kstutrud
    kstutrud New Member
    Sep 9, 2010
    toilet bowl water siphons away
    Just curious what the problem ended up being?
    I installed 2 American Standard toilets last month. One is fine, the other one loses its bowl water after a minute or two. I can flush and the bowl fills ok, but within a minute the water level siphons down to almost exposing the hole in bottom.
    Refill tube is positioned correctly in tank.
    Help!
  15. hj
    A crack in the bowl that causes the water to drain out is seldom where you can see it. In many cases, the problem exists for a long time, but a leaking flapper, or other source of water, continually compensates for the lost water. It is only after the toilet is repaired and the leak fixed, that the problem becomes evident.
  16. kstutrud
    kstutrud New Member
    Sep 9, 2010
    Thanks hj - but isn't this kind of a rare occurrence given that the toilet is brand new? It's very weird that it would have a crack in the bowl...
  17. Terry
    Aug 17, 2004
    It happens all the time.
  18. jadnashua
    AS has had spotty QC over the recent times, and no, this is not all that uncommon from the comments here.
  19. kstutrud
    kstutrud New Member
    Sep 9, 2010
    Finally made time to try the food coloring in the bowl - let it sit for 8 hours, then pulled toilet. No visible wicking of color to the underside of the toilet. No cracks that I can see, no signs of moisture under the bowl. What in the world is going on? I set the toilet again hoping something had changed, but same problem - bowl nearly empties after about 30 seconds...help!
  20. jadnashua
    The bowl could be defective and leaking directly down the drain.
  21. ToiletDrain
    ToiletDrain New Member
    Sep 19, 2012
    Alabama
    Toilet Bown Drains Slowly After Flush My Story
    Thanks TerryLove for this forum...
    Here IS what happened to me and this is no theory. I wanted to mention this here because this is the first place that pops up for a search of "water drains from toilet bowl."
    So, last night no problem. This morning the bowl fills and just kind of slowly drains. Took maybe 30 seconds.
    The plunger wouldn't work because the water kept draining. The hosepipe I stuck up the old spout ran and ran and no help.
    I suspected right off that there was a clog, but I kept at it. Finally I went outside. There it was.
    What happened was that it was clogged. But, unbeknown to my humble self, all that water was flushing outside the bathroom wall through the vent pipe. (Which just happens to be a pipe sticking out which is connected to the flue thingy from time to time. This time it wasn't. So, when I'd flush, run water, whatever, it was just going outside. Dittos the water in the bowl. I don't know how it siphoned out, but it did.
    The fix was to get my handy plumber snake and do some shoving. Luckily it is a straight through shot from the vent pipe through the trap and on out to the sewer. I shoved awhile and then blessed resistance! YES!
    Back inside I flushed and it was perfect. I did it like 5 more times.
    The moral to this story is that if you own one of these new short flushing water saving miracle toilets like me, you MUST HOLD that handle down to MAKE SURE ALL the water moves the load on down the system and out. If you don't, and it hangs mid way, like happened to me, there is probably no help for it outside of the old roto rooter treatment.
    Of course, if the up pipe had been connected to the vent pipe, the bowl would have just filled up and maybe the plunger would have worked. But as happens sometimes it was the perfect poo poo storm.
    When your toilet is draining out like mine, consider a clog. Try the simple things first. There is always time to tear out your bathroom if need be.
    How'd you like my handle, btw???
Similar Threads: Toilet water
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Yesterday at 9:53 AM
Toilet Forum discussions Toilet Water Gets Gone Feb 1, 2017
Toilet Forum discussions Better Toilet for Hard Water/Iron Conditions? Jan 30, 2017
Toilet Forum discussions Toilet water supply has been off a while...try to turn back on now and get a horrible loud noise... Jan 18, 2017
Toilet Forum discussions Toilet bowl slowly leaks water Dec 15, 2016
