Toilet to Septic tank issues
hygron
Hell Hole Swamp
hygronomics.com
Recently we have experienced heavy rains for 2 months or so. The ground is saturated, and I am wondering?
If water is not draining off after rains; Can that affect our toilet flushing due to septic tank being under water.
Toilet is flushing as if there was a clog, but I believe there is "No clog". We have treated the toilet plumbing with a commercial drain opener, but after 2-3 days, and rain, it starts flushing slowly and "weezing", a bit.
Any ideas?
JohnjH2o1
Florida
If the ground is saturated around the septic system then that is the cause of your problems.
John
I've seen some installations where the septic is located on a higher piece of ground and it's pumped to that location.
If your ground water has filled the lines where it is, it's going to be slow going. You must have a gravity system.
I need to add that forum you were mentioning too.
