Toilet supply with built in shutoff
Discussion in 'Toilet Forum discussions' started by Peanut9199, Nov 5, 2008.
  1. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    I've had somes calls and wanted to share.
    Home Depot and maybe some other places are selling a Watts (Floodsafe) S/S toilet supply that has a built in shutoff that if the toilet leaks it will shut off the water.
    The problem is it affects the Toto toilet and will not supply water to the fill valve.
    I'm not sure why but it must sense a loss in pressure and stops.
    So if you get a call with a fill valve not supplying any water check the supply tube.
    http://www.watts.com/pro/whatsnew/whatsnew_floodsafe.asp
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    That problem is well documented and occurs on many fixtures and appliances when Watts Floodsafe supplies are installed.
    IMHO they are Junk!
  4. Terry
    Aug 17, 2004
  5. Peanut9199
    Apr 23, 2007
    Ontario, Canada
    Wow i wish i joined this forum sooner.
  6. hj
    Floodsafe
    FLoodsafes think any high flow is a rupture and shut off. When you turn on the control valves you have to do it gradually or they will activate and then you must turn off the valve and remove the Floodsafe to reset it and then try again.
  7. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    They have washing machine hoses with the same valve. Same problem with false alarms.
  8. Redwood
    Dec 15, 2007
    Service Plumber
    I had a go round with a condo association regarding them requiring the use of floodsafe washing machine hoses...
    They had 100 PSI. water pressure, yet wouldn't have a PRV installed, and they were requiring floodsafe washing machine hoses...
    Somehow it just wasn't working...
    Go figure!
Similar Threads: Toilet supply
Toilet Forum discussions Toilet water supply has been off a while...try to turn back on now and get a horrible loud noise... Jan 18, 2017
Toilet Forum discussions Toilet supply line behind drain Jul 12, 2016
Toilet Forum discussions Floor Water Supply - What Toilet Options Are Best? Nov 30, 2015
Toilet Forum discussions Pressure assited toilets: best supply pressure and outflow pipe joint stress Aug 27, 2015
Toilet Forum discussions Toilet Water Supply Line Issue May 8, 2015
