Toilet "sucking" water from tub trap?
Houseman
New Brunswick
I have what I think is a weird problem. When I flush my toilet, there is a gurgling sound in my bath tub. When I run some water in the tub,and then flush, the noise stops, for a bit, (3/4 flushes) and starts again. Even more weird. this only happens on an intermittent basis. Sometimes it will go weeks without happening, then do it for a week. It seems that for some reason the toilet is sucking the water from the trap for the bath. I thought it might have something to do with the snow on the roof covering the vent stack but I just checked it from the ground) and it is open. Could there be a plug of snow inside the stack pipe that I can't see from the ground? (stack should be warm enough to prevent that?)
Any thoughts/ideas would be most welcome. This is very annoying!
Trev
Houseman
New Brunswick
Would that cause an intermittent problem Terry? I have been reading here for an hour and came across threads that talk about dry traps(this one is used daily). I am kind of concerned now because I also read about "partial" clogging of the lines.
If it is siphoning, it is because the toilet is flushing "good", so it would not be a stoppage problem. But, it could also be caused by air being forced out of the tub drain because of a stoppage. Your problem could be caused by NO vent, an IMPROPER vent, or a PLUGGED vent. The vent COULD be plugged with frost and you would not be able to see it without looking INTO it.
Houseman
New Brunswick
Thanks guys. I would tend to think that it is flushing "good". Nothing has changed in years so its not "no"vent or "improper" vent. Perhaps frost plug. I guess as long as it flushes well all is good.
Thanks for your time both of you. I do appreciate it!
FWIW, a toilet will often flush well without any vent...it's just the other things on the line that may have problems.
quote; a toilet will often flush well without any vent
FWIW, almost EVERYTHING will drain better without a vent. The vent is to keep it from draining so good that it siphons the water out of the trap. I once had a customer who wanted me to connect his tub drain to the stack. He had a 10' pipe dropping out of the tub all the way to the basement where he wanted me to make the connection. I told him that if I made that connection, the tub would drain so "good" that it would suck everything in the room, including the baby, down the drain when he pulled the plug. A bit of hyperbole, but he got the message.
Harrygbh
New york
That is normally because the tub is not vented, and the toilet siphons the p-trap.
Well why would that suddenly happen then after 40 yrs of not happening? Also if venting from rooftop is clogged wouldnt
all fixtures in house regardless of floor have sewer smell. Wouldnt all traps get sucked dry when toilet flushes
