A couple of things to consider: the originator of the MAP test says anything over 500g is plenty. Many of the manufacturers have optimized their designs to flush the plastic wrapped paste, and fail with with 'real' stuff. They are a comparison, but other things need to be taken into consideration. Many of the Kohler products require unique, proprietary parts to repair (the flappers, seals, etc.), and can be quite expensive and difficult to find - often only available from Kohler (unlike many others, where you can pick the part up at the local big box store). Then, check out the actual waste path...some designs have some very severe obtuse angled turns, and are prone to clog (not as much an issue with nice smooth plastic wrapped stuff). So, a comparison probably could be made, but my preference would be to not look at either! I tend to avoid anything Kohler. Take a close look at the side of the thing and check out the actual waste path. Nice smooth, long angles will flow better...pick the one that has the best path and you have a chance. Toto is the largest toilet manufacturer in the world, and makes some good performing units, with some of them made in Georgia...can't always say that about many US brands.
