toilet flange below top of floor
Discussion in 'Toilet Forum discussions' started by Pabs, Jan 26, 2011.
  1. Pabs
    Pabs New Member
    Oct 10, 2009
    Moncton, NB (Canada)
    Hi all
    I just finished taking the tile off the bathroom floor in order to get it ready for the new tile (and heating cables)!
    the toilet flange is sitting on top of the plywood right now and in decent shape... some water must have leaked since the wood is discolored just a tad around the flange
    but aside from that it seems fine..
    Normally I would install the flange on TOP of the finish floor (i.e. the tile). but can I get away and leave the flange that is there and install something like this
    http://www.ferncoconnectors.ca/plumbing/wax-free-toilet-seal
    if I go this route, the finish floor would likely sit 1/2 inch above the top of the flange...
    the fernco toilet seal would be long enough to still get a good grab ...I think...would that be ok or do I need to remove that flange?
    oh and putting double layers of was seals is not an option for me since I'll be doing in floor heating...
    removing the flange would be a pain in the butt since I don't really have access from below... I would need to cut out the sub floor.. I rather not if there's an alternative
    thoughts?
    thanks
    Pabs
  2. Terry
    Aug 17, 2004
    Fluidmaster makes a waxless seal that would work for that. We push the adapter onto the bowl first, and then set the bowl over the flange.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The Fernco waxless seal looks quite similar to the Fluidmaster, so I would expect it to work well. I don't know what the installation instructions are for the Fernco, but I would stick the flange on the toilet first then set the toilet. Fluidmaster's instruction sheet is best used as toilet paper. I've tried it both ways, and putting the seal on the toilet first is by far the easiest.
  5. jadziedzic
    jadziedzic Member
    Aug 4, 2006
    New Hampshire
    Manufacturers of in-floor heating systems recommend keeping the heating cables away from the flange; Laticrete says at least 4-6 inches, while NuHeat says 6 inches from the center of the drain. I have a hard time believing there would be enough heat build-up under the throne to melt the wax unless you had the temperature cranked to the 100+ degree range and ran the cable right next to the flange. Another alternative is the el-cheapo flange extenders that you stack on the existing flange (with silicone sealant between the flange and the extender).
Similar Threads: toilet flange
Toilet Forum discussions Toilet Flange not Flat/Level Tuesday at 2:21 PM
Toilet Forum discussions Odd Offset Toilet Flange Dec 21, 2016
Toilet Forum discussions Toilet Flange Height on New Tile Dec 19, 2016
Toilet Forum discussions Toilet flange question Dec 7, 2016
Toilet Forum discussions How do I Install Toilet Flange to Stubbed Pipe in Concrete Slab Nov 20, 2016
