toilet bolt
Discussion in 'Toilet Forum discussions' started by peterl, Apr 12, 2010.
  1. peterl
    peterl New Member
    Mar 17, 2010
    cal
    What do you guys do if the bolt is long that the cap is just hanging on the bolt as oppose to the cap being snug? Thanks
  2. Terry
    Aug 17, 2004
    We cut the bolt shorter after the nut has been tightened down.
  4. peterl
    peterl New Member
    Mar 17, 2010
    cal
    what do you guys use to cut the bolts? Thank You
    I don't want to sound really dumb but I am thinking a dremel or bolt cutter. Just curious what you guys in the industry use?
  5. jadnashua
    Hacksaw. A dremmel with a cutoff blade would work, too. You can also buy segmented, break-off bolts that you grab with a pair of pliers after tight and break off the excess at one of the notches. Not worth it to reset the toilet now, but maybe next time. If you cut the bolt before you put the nut on, you may not get the nut on! You can get it off later because the nut acts like a thread chase and straightens out the bent threads you made by cutting it off.
  6. hj
    IF you use a bolt cutter, you will need it again when you have to remove the toilet. A Dremel tool also will create a burr which could cause you a problem if the bolt is not secured to the flange. I use a mini-hacksaw which gives a guick smooth cut.
Similar Threads: toilet bolt
Toilet Forum discussions four bolt toilet tank Dec 13, 2016
Toilet Forum discussions Why are toilet bolt caps so short? Please make them taller. Dec 5, 2016
Toilet Forum discussions Kohler Memoirs 3 Bolt Toilet Tank Nov 30, 2016
Toilet Forum discussions Rustproof toilet tank bolts ? Aug 12, 2016
Toilet Forum discussions Cutting toilet closet bolts Apr 8, 2016
