Toe kick heater hot water
Discussion in 'HVAC Heating & Cooling' started by marklamberti, May 24, 2013.
  1. marklamberti
    marklamberti New Member
    May 24, 2013
    staten island
    Hello;
    I am redoing my kitchen and dinning room aprox 12x25 in size. I am removing 2 radiators and plan to heat with only toe kick heaters. The room will be split with a peninsula. I was planing on using only one tow kick heater in this however i am now thinking i may be better with 2 smaller units one facing the kitchen side of the peninsula and the other facing the dining area.
    Just looking for opinions on this.
    also can i daisy chain 2 of these together? I have a hot water boiler with 4 zones and 4 pumps with individual 1/2 pex runs to each rad. These will be tied into one pex run and be alone on that run or together with each other.
    also aprox what btu should i shoot for here. I am in ny and the rooms will have r-13 in them. with 3 windows
    thanks
    mark
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    For approximating the BTU loads we need to know:
    How many square feet of window, and what U-factor (if known) or type? (single pane, double pane, low-E, argon filled, whaddevah.)
    How many square feet of exterior wall (not including window area.)
    Then there's the consequential issue of the output temperature of the boiler water...
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Based on my limited experience with a hydronic heater in the kickspace under my kitchen sink a few years ago, I would guess you are going to have difficulty getting anywhere near the heat output of the radiators you are removing.
    That would depend upon whether the water leaving the first unit would still be hot enough to start the fan in the second unit, but you could control both fans with one sensor.
    Have you considered hydronic heat either in or under your floor?
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Breacon Morris makes two models, the k42 and the k84. The 41 puts out 41000 btu's and the 84 puts out 8400. They should be placed so they don't blow hot air across your feet so not where you stand frequently as the hot air gets quite uncomfortable. They need to be piped using mono-flow tee's also because they use 1/2" inlets and outlets and running straight through causes a whole lot of restriction in the loop. The k84 equals about 14 feet of 3/4" baseboard so a single unit should suffice, especially in a kitchen where we generally don't like to over radiate due to heat gain from appliances. My own house is 150 years old with very little insulation and single pane windows and I have no heat in the kitchen at all.
    http://beacon-morris.com/html/kickspace_heat_twin_flo.asp
Similar Threads: kick heater
HVAC Heating & Cooling Toe Kick Under Kitchen Counter Electric Heater Nov 1, 2014
HVAC Heating & Cooling Gas Fired Heater - Fan kicks back on briefly after normal cycle completes Feb 4, 2012
HVAC Heating & Cooling Quiet, Reliable Residential Toe Kick heater Sep 19, 2011
HVAC Heating & Cooling toe kick heater Jan 5, 2011
HVAC Heating & Cooling beacon morris toe kick heater Dec 29, 2010
