Tighten tub spout
Discussion in 'Shower & Bathtub Forum & Blog' started by markdiy, Oct 14, 2004.
  1. markdiy
    markdiy New Member
    Sep 20, 2004
    I've installed a new tub spout that screws onto a male adapter. Problem is that when it's fully tight against that side of the tub surround, it's pointing up.
    Are there any tips on getting this tight against the wall after backing it off 1/2 turn so it points down?
  2. hj
    spout
    You will either have to loosen the material around the pipe so it might be able to move as you tighten the spout the rest of the way, or leave it away from the wall and caulk the gap.
Similar Threads: Tighten spout
Shower & Bathtub Forum & Blog How to tighten bathtub brass insert Mar 22, 2017
Shower & Bathtub Forum & Blog This has turned into a mess.......can't tighten dome enough Jan 27, 2013
Shower & Bathtub Forum & Blog Could Not Tighten Shower Drain Nut W/Wrench....?? Aug 25, 2012
Shower & Bathtub Forum & Blog How do I tighten down tub faucets if the tile wont allow access? Sep 3, 2008
Shower & Bathtub Forum & Blog Hand tighten or with wrench Jul 3, 2006
