The NSPC permits s-traps?
Discussion in 'NSPC Plumbing Code Questions' started by North Jersey, Jun 30, 2010.
  1. Terry
    Aug 17, 2004
    Which ever way you go, could you post some pictures when done?
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Hi guys. Here in Illinois it is against code to run the disposal into a end waste and use a single trap. Each fixture has to have its own trap. The way we do it is a 2" line in the wall come out with a 1 1/2 double Wye. The center of the double Wye would be the clean out, then each side of the double Wye would have a trap. So the picture here is not that far off base to what meets the Illinois plumbing code.
    [​IMG]
  3. North Jersey
    North Jersey New Member
    Jan 1, 2009
    If I'm ever done, I'll gladly post some pictures. :)
    Terry and Doherty tell me the type of installation in the picture will result in siphoning. Have you ever experienced this phenomenon with your double wye configuration?
  4. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Nope never had an issue. As I said its allowed here in Illinois. Its best to check with your local plumbing inspector to see what meets the code by you.
  5. North Jersey
    Jan 1, 2009
    Why not disconnect the p-trap at the union for a cleanout? What's the benefit of the double wye?
  6. Terry
    Aug 17, 2004
    There always needs to be a cleanout on a kitchen sink.
    The double wye makes sense too. One trap doesn't run by the other like in the first drawing, it's more like a double fixture fitting in that the arms come in equally and not by each other. The cleanout in the center would be the same in other codes as the clean out either on the arm or on the vertical below.
    Kitchens need cleaning out more then most other fixtures because of the grease, and from the disposers.
  7. North Jersey
    Jan 1, 2009
  8. Terry
    Aug 17, 2004
    It would seem to be true, however we always have to look at the local inspector and please him or her.
    Years ago, I plumbed seven meat markets for a large chain. Since the stores were located in different cities and counties, I had to meet with each local inspector to find out how I was going to pass inspection. Everything was supposed to be UPC code, however I wound up plumbing each one differently.
  9. North Jersey
    Jan 1, 2009
    Those prima donnas. :D
  10. North Jersey
    Jan 1, 2009
    I think the branch vent below is very dubious, but how does the rest of the sketch look?
  11. North Jersey
    Jan 1, 2009
    The inspector didn't allow that connection below the flood rim, even though the ejector would prevent a backup in the event of a clog. I guess a foolproof system is the way to go. I'll just have to tie into a different vent group where I can connect at an appropriate height above the flood rim.
    The inspector also told me that he wanted a 2" vent for the ejector, but I think the applicable code says 'the sump for macerating toilets shall be vented with a 1-1/4" pipe.' (NSPC 11.7.10) The manufacturer's guideline for my pump is 1-1/2", and my system is a self-contained SaniFlo unit that is designed to sit above grade. The inspector is the type of guy who seems pretty open to feedback, but I don't want to risk burning any bridges on a fairly minor issue. I may need to rely on his generous spirit if I ever try to expand my septic system.
  12. North Jersey
    Jan 1, 2009
    The inspector ended accepting the manufacturer's instructions (1-1/2" vent) becaue the SaniFlo is more like a macerating toilet than an ejector pump.
Similar Threads: NSPC permits
NSPC Plumbing Code Questions Does the NSPC allow AAV's ? Jul 23, 2010
NSPC Plumbing Code Questions Link to the 2006 NSPC PDF Jul 13, 2010
NSPC Plumbing Code Questions NSPC stack venting question Jul 12, 2010
NSPC Plumbing Code Questions Need help with plumbing for washer, NSPC Jun 8, 2010
NSPC Plumbing Code Questions Condensate Line to Sewer Pipe, NSPC Jun 4, 2010
