Tankless gas water heater overflow pipe?
philipk65
CA.
Hi,
I just move into a new house and it has a Eternal gas (propane) tankless water heater.
I've noticed that it has a overflow PVC pipe running to the outside of the house and it seems to always be dripping. Is this normal?
Also, would I be better off to switch it out for an electric one?
Thanks! Kevin
The Eternal tankless is a high efficency model, and what you are seeing when it is running is condensation. That's normal.
When a heater squeezes all the heat it can, a byproduct in the exhaust is water. That water needs to be drained off. You will notice that the exhaust is plastic pipe. That's to prevent rust through.
http://www.bostonheatingsupply.com/eternalparts.aspx/
If you have a floor drain, you can run the condensation there.
philipk65
CA.
Thanks Terry!
I your opinion, would you stick with this Eternal propane tankless or switch to an electric model?
Thanks again. Kevin
