Taco RMB or X Block?
Discussion in 'HVAC Heating & Cooling' started by nedjinski, Feb 14, 2007.
  1. nedjinski
    nedjinski New Member
    Feb 5, 2007
    Has anyone had experience with either of these Taco products? they seem to solve lots of problems and make it so you don't need so many separate components - great ideas, but do they work? or have some limitations?
  2. bobday
    bobday New Member
    Apr 16, 2007
    Taco Rmb
    I found it difficult to set up (confusing instructions). Very compact and went in nicely. I know of nothing better. It is a bit pricy but considering the alternatives?
    I sugget you get themanifolds that attach to it. I also had to supervise it with a zone valve in series. If there is any pressure in your system between the high side of the boiler and the low side it will feed through the mixing block and not be able to control the heat. Remember you don't want the floor to go above about 102 ever. My floor run around 80 to 85 which is just lovely. (I live in Alaska).
    Watch out for the Manual/automatic switch. It is very poorly defined (no labeling and didnt match the drawing). It was in Manual from the factory! I spent a lot of time trying to get it to work. Once the switch was placed in AUTO it worked a lot better!
Similar Threads: Taco Block
HVAC Heating & Cooling Taco zone valve coming loose Dec 16, 2015
HVAC Heating & Cooling Taco ZVC404-EXP Problems Jul 15, 2013
HVAC Heating & Cooling Taco Check Valve Chatter Dec 14, 2012
HVAC Heating & Cooling Issue with Taco 241 swet-check Jan 19, 2009
HVAC Heating & Cooling Taco Zone Valve Dec 29, 2008
