Taco ESP Zone valves
Discussion in 'HVAC Heating & Cooling' started by Yaniguy, Oct 20, 2008.
  1. Yaniguy
    Yaniguy New Member
    Oct 20, 2008
    Hiyas,
    My home has a gas furnace with forced hot water base boards. It's relatively new 2003.
    The problem is it has Taco esp zone valves 3 zones all have been replaced at least once.
    The HVAC company that did the original work replaced them saying Taco improved the motor. Well I have 2 burned out motors that can't turn the ball valve.
    What should I do replace them with the same or get a new valve system?
    Thanks in advance
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    you probably have too many zone valves on a transformer, or the transformer does not have enough amperage. The valves themselves are quite dependable.
  4. Yaniguy
    Yaniguy New Member
    Oct 20, 2008
    There are 3 zones and the power supply is from taco also it has 4 zone capability and is 24vac. After some research they have discontinued the ESP and are now called EBV. Same concept with a better motor from what I can tell.
    Taco is sending me 2 new motors for free so I hope they work.
    Btw I live in southern Maine. Can you recommend a good company if I ever need work done on my furnace. I kinda have had it with the people who installed it hence taking matters into my own hands.
    Thanks
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Dunno, Maine's a big place. Where ?
Similar Threads: Taco Zone
HVAC Heating & Cooling Taco zone valve coming loose Dec 16, 2015
HVAC Heating & Cooling Taco Zone Valve Dec 29, 2008
HVAC Heating & Cooling Taco ZVC404-EXP Problems Jul 15, 2013
HVAC Heating & Cooling Taco Check Valve Chatter Dec 14, 2012
HVAC Heating & Cooling Issue with Taco 241 swet-check Jan 19, 2009
