I'm replacing the sump basin/liner in my home which is currently a perforated 5 gallon bucket surrounded by gravel. I have an interior drain system that has two pipes terminating into the gravel pit area (but not into the basin itself - the water dumps into the gravel and through the holes in the bucket). We have a high water table and the sump runs every few minutes on normal days.
My question is: should I replace the bucket with a solid liner, with openings for the drain pipe to go directly into the basin to be pumped out.... or should I use a perforated liner that allows water to come in in addition to the drain pipes? It seems counter-intuitive to me to have the drain pipes empty into a basin with holes in it... but maybe I'm missing something and water needs to be allowed in in addition to the drains?
I really appreciate any advice you can give. Thanks!
