Jonny5
I'm in the final stages of my shower remodel and ready to install final plumbing fixtures. I had a plumber out to do rough-in work a month ago but figured I could handle the 'easy' job of putting a few fixtures up myself. The shower set up has both a fixed shower head and a wand on a hose, problem is with this wand/hose connection. There are 3 parts to connect here; roughed in connection behind wall, fixture that sits flush on the shower wall and a short piece of 1/2" threaded pipe between those 2 things. I have two sections of pipe, 2" and 2 1/2", unfortunately neither really work. The 2 1/2" is a good 1/8" too long and the 2" is obviously too short. I've called around to several plumbing supply places to see if by any chance anyone carries a 2 1/4" piece or can thread a piece that short, no to both.
I'm thinking my only option is to apply quite a bit of (Teflon) pipe tape to the threads of the 2" section and cross my fingers but is there a better choice for this? I'm a little leery on having that much tape on there and having it leak. The pipe tape is actually what the plumber said to do if I needed to use the 2" section of pipe. Would using either pipe tape or pipe dope be "better" in this situation?
I know the threads are tapered on the pipe so I'm guessing cutting an 1/8" or so off the longer piece wouldn't really do anything for me.
Any help here would be greatly appreciated as I'm hoping to finish this job ASAP. And pulling some tile and opening the wall isn't really an option I want to do.
Thanks in advance!!
Thanks in advance!!
