Sudden Change to PSI: HELP?!?
Discussion in 'Irrigation / Sprinkler Forum' started by maddog-99, Apr 10, 2009.
  1. maddog-99
    maddog-99 New Member
    Apr 10, 2009
    6 months ago the sprinkler system in my back yard worked great.
    There are 4 stations with 3-4 sprinklers on each, some impact some pop up.
    Recently the lawn was fading & I went to inspect.
    When running on the automatic system (from the controller) water comes out, but the pressure to the heads isnt even enough to get the impact heads to hit & flip into rotating.
    When trouble shooting though I used them manually (by turning that small little knob on the valves). Manually they flow GREAT. strong & vigorous.
    There is no visible valve damage.
    I understand you lose pressure through an auto system, but my drop off has to be at least 40%.
    Any suggestions on what I can do? I have a incoming water pressure regulator & I have that maxed out & do not want to overdo it & blow my in house valves.
    This was not a problem 6 months ago. The auto system ran like the manual in terms of strength.
    My confusion is in the difference between auto & manual as stated above.
    HELP. Wife is about to leave me for a man with a better lawn! :eek:
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    If manually opened valves get it done, then you need to examine the solenoids, or maybe the diaphragm assemblies.
Similar Threads: Sudden Change
Irrigation / Sprinkler Forum New sprinkler timer suddenly won't switch to 2nd zone manually May 22, 2011
Irrigation / Sprinkler Forum 2 out of 4 zones suddenly don't work Jul 2, 2007
Irrigation / Sprinkler Forum Backflow device for greywater changeover device Apr 29, 2015
Irrigation / Sprinkler Forum How to change timer on sprinkler system Jun 25, 2012
Irrigation / Sprinkler Forum How to change the spinkler pattern? Jun 13, 2008
