submersible run with no pressure tank or switch?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by merc4, Sep 4, 2012.
  1. merc4
    merc4 New Member
    Sep 4, 2012
    ohio
    I just need to pump from a spare well, into my pond (drought) Can I just run the wires and plug it in, with no switch/pressure tank? Obviously it would be Running non stop for a day or 2 at a time?
    thanks, Merc
  2. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    We do it all the time. Just make sure that there is no way it can be blocked in while running. It will either nuke the pump or nuke the well, and either one can be bad.
  4. merc4
    merc4 New Member
    Sep 4, 2012
    ohio
    Thanks Wellman, appreciate the quick reply!!
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    How deep is the well and the static water level? If the well and the pond is in the same aquifer, you are just going to recirculate the water.
    If there is not enough head on the pump, you might risk up-thrust on the impellers which can be detrimental to the pump. You might consider choking the flow back a bit to simulate head.
Similar Threads: submersible pressure
Pumps and Tanks Well Forum & Blog Help! Submersible well pump runs but won't build pressure over 30 psi! Nov 13, 2015
Pumps and Tanks Well Forum & Blog Pressure Loss - Submersible Well Pump Aug 7, 2015
Pumps and Tanks Well Forum & Blog Thoughts on a submersible pump and pressure tank Apr 27, 2015
Pumps and Tanks Well Forum & Blog Tankless Submersible Well Pump losing pressure Jul 7, 2014
Pumps and Tanks Well Forum & Blog Pressure differential from well submersible pump Nov 16, 2013
