Submersable pump blues
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by nascar fan, Mar 17, 2007.
  1. nascar fan
    nascar fan New Member
    Mar 17, 2007
    Hello, i have a problem i need help with. I'm having a pump issue. I pulled my well pump, cleaned it and turned it on with just the pump in the water and it pumped fine. I put all the pvc pipe back on it, about 50 feet down and turned it back on and nothing. I noticed that the wires are put together in one spot with wire nuts. They are under water, will this cause a problem? I'm lost, i'm not a plumber at all.
    Also does any one know how deep a 1/2 h.p. jet pump will pull? I have one that i was going to replace the submersable pump with but not sure if it will work as well or not. I'm guessing my well in around 50 to 70 feet deep and the house is about 30 yards from the well. Is this a good idea or a waste of time?
  2. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    Wire nuts under water??Ask yourself this,"is it ok to drop a hair dryer in the bath tub while its running?" You need an electrical water proof heat shrink kit for that connection.That wire nut set up is bad news. I would stick with the submersible pump idea,just get it wired right.
    SAM
  4. nascar fan
    Mar 17, 2007
    Thank you !!
  5. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    What was it doing, or what was the issue before you pulled it?
    Is that how the connections were before you pulled the pump? And if so, was there any evidence of something like at least a little silicone or anything else somebody had used to try to seal those connections? If so, that might confirm the cause of your problem before you might have to pull your pump once again.
  6. Rancher
    Rancher Guest
    A shallow well jet will pull about 25 feet.
    Rancher
  7. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    A jet pump will NEVER work as well as a submersible pump that is properly matched to the well and the demand. If the well is big enough for a submersible, that is the correct choice.
    The submersible is probably twice as efficient (half as much power for the same delivery of water), never needs primed, is not marginal on pressure, and is quieter.
  8. sammyhydro11
    Dec 20, 2006
    Massachusetts
    I agree with bob. Stick with the submersible pump.
    SAM
Similar Threads: Submersable pump
Pumps and Tanks Well Forum & Blog. Water is life. Water rusty and full of sediment after new submersable well pump was installed May 17, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Jet pump to submersable conversion questions. Sep 8, 2012
Pumps and Tanks Well Forum & Blog. Water is life. picking submersable pump/ calculating resistance from a long run of water pipe Dec 31, 2011
Pumps and Tanks Well Forum & Blog. Water is life. replacing check valve on submersable pump??? May 6, 2011
Pumps and Tanks Well Forum & Blog. Water is life. 4 in. Submersable Water Pump Question! Oct 29, 2009
