Steam pipe leak
Cluelessguy
New York
I have a leak coming from the copper male adapter fitting and would like to know if there’s a way for me to patch it or fix it altogether without getting a professional to charge me an arm and a leg? Seems like the threading is causing the leak. I tried pipe thread sealant but it’s still leaking. Any help would be highly appreciated.
Marlinman
Jacksonville Florida
Try using X-Pando joint compound or Hercules Block.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Marlinman, I think the o.p. is describing a leak at the threads and wants to apply a 'sealant' on the surface to stop a leak.
my answer: any joint that is under pressure and experiences exp/contr from heat cycles will need to be redone...removal and repaired.
John Gayewski
Iowa
A braze would fix about any leak.
If you use the goo and it works great, but plan it not working eventually. I which case just replace the joint.
Tuttles Revenge
I had a 500gal hot water storage tank supplying a car wash that I couldn't get the threads to stop leaking. I could only fill and test and drain the tank 2x a day and I was getting really frustrated with it. At the same time I was working on another project with a pipe fitter who showed me a trick where he would hammer in a the pencil lead from a contractors pencil into the point where the leak was coming from until the leak stopped..
he also gave me the dregs of his Anaerobic pipe dope which would seal more as it came into contact with water.. I used the dope. But that requires cutting and repairing the cut section after you Think you've gotten the threads sorted out.
