Square D panel?
Discussion in 'Electrical Forum discussion & Blog' started by Mad Plumber, Dec 21, 2007.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    I have an old sq.D panel CAT. QON-12M. Is it possible to purchase tandem breakers for this panel? I need to add more circuits.
    Roy
  2. hj
    panel
    The schematic inside the cover will usually tell you if they will fit, but normally if it can use tandem breakers the model would end in two numbers. One is the total standard breakers and the other is the maximum using tandem breakers. The difference between the two numbers is the number of tandem breakers possible.
  4. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Worst case scenario just add a sub panel...
Similar Threads: Square panel
Electrical Forum discussion & Blog How To Wire a Square D QO220GFI 240v, 20-amp Double Pole Breaker Jan 26, 2015
Electrical Forum discussion & Blog Square D 2 pole breakers Oct 11, 2012
Electrical Forum discussion & Blog Square d May 14, 2010
Electrical Forum discussion & Blog Square D Circuit Breaker Recall Nov 2, 2007
Electrical Forum discussion & Blog Square D well pressure switch Sep 23, 2007
