Sprinkler zone not turning on
cheapsaket
I have a rainbird ESP-6TM system.
There are 6 zones and the system will work fine where it will cycle through zones 1, 2, 3 but then it wont continue to zone 4,5,6.
There is no mechanical issue as I can manually turn on the valves for the zones 4,5,6 and they will work fine.
There seems to be some electrical issue in the valve box for zone 3 where sometimes if I jiggle the wires a bit, the zone 4 will start and the system will cycle through fine.
But the problem returns the next time.
The problem seems to have started after the valve box for zone 3 started leaking.
I would really appreciate some help in trying to DIY and fix this issue.
I had one guy take a look and he was asking for $600 for the problem.
Gary Swart
Yakima, WA
The usual way of wiring electric valve from the controller is to run individual hot wires to each valve and to link the common (ground) wire from valve to valve. I would look at the connection between valve 3 and valve 4. I suspect it has separated, probably inside a wire nut.
