sparkling water??
Marco_Guy
FL
OK. Not doing another manual regen. Hopefully the problem is resolved.
Thanks for the help.
Marco_Guy
FL
Just noticed the "foamy/salty" water sample I saved from last night has a bunch of turquoise sediment in the bottom of the glass.....
Gary Slusser
That's all folks!
That is a clear glass, the water has the same turquoise tint.
Then something may be casting a blue tint reflection on the glass because I see blue above the water in the glass, especially on the left side and front of the glass. Try a clear smooth sided glass.
I've treated a lot of aggressive/corrosive water and have never seen anything like that before.
Tom Sawyer
Maine
That sort of copper corrosion can be a result of either high or low PH. In the North East we get a lot of low PH water conditions. I suspect the foamy/salty water may have dislodged that corrosion from inside your pipes which is why I asked if you know the PH of your water.
Marco_Guy
FL
i don't know the ph. maybe i can have it checked at my pool supply place...
if it is copper pipe corrosion, wouldn't it have shown in the water when i put the water in the glass from the faucet? once the foam went away, the water appeared clear until i let it sit overnight.
F6Hawk
Alaska
Wait a minute... are you saying the sediment in that glass wasn't there when you poured it, but showed up in the glass the next day???
Marco_Guy
FL
Unfortunately the wife tossed the sample last night. Hopefully it won't occur again....
