Solar Preheated Water and Oil Fired Boiler?
Discussion in 'Solar and Geothermal Water Heating Forum' started by Breakitnfixit, May 17, 2008.
  1. Breakitnfixit
    Breakitnfixit New Member
    May 17, 2008
    Vermont
    Hello,
    Currently have 20 yr old Trianco oil fired boiler running baseboard heat (closed loop?) and a DHW coil. Water from deep well runs 40-45 degrees year round.
    The south facing 1800 sqf house is well insulated and I've only got a few more drafts to track down. Aside from adding insulated curtains/shades for the windows there isn't alot more I can do to keep the warm air in.
    I thinking of adding evacuated tube (I'm in Vermont) solar collectors big enough to supply all DHW for the Summer and to supplement DHW in the winter as well as preheat inlet water to the boiler. I figure this could save 200 gal oil/yr just by keeping the boiler off in the summer.
    Since the boiler is old and its chimney is falling apart (cinder block) I'm prepared to replace the whole system..
    I'm thinking oil is still my best option (but I'm open to ideas here) and have some questions on configuration:
    Should I keep it simple and pump closed loop solar heated solution through a heat exchanger in a well insulated hot water tank (120gal) and use water from this tank to supply the cold water inlet on the boiler (instead of from the well)? Additionally, the boiler could cool down the water from the baseboard loop by running it through an exchanger in this same tank? It seems like Buderus makes a boiler that would accomodate this set up.
    Would this setup work (i.e. actually reduce oil consumption)? Am I right in thinking that 120 deg water from the tank could just 'flow through' the boiler for DHW without needing the boiler to come on? Would this also be preheating the water in the baseboard loop and is that ok? What are some considerations for routing the water? I'm trying to avoid lots of pumps and controllers.
    My brain is starting to cramp trying to figure this out!
    Thanks, CD
  2. BigLou
    BigLou New Member
    Nov 7, 2007
    Brekintnfixit,
    Seeing as you are open to spending the money on a whole new system and oil is currently close to $4.00/gallon why not go for broke and do it right.
    Oil is terrible, dirty, inefficient heat and in my opinion should be out lawed as a home heating option. The have condensing boilers but I am not sure you can buy one in this country yet.
    I would suggest you get a High Efficiency gas(natural or propane) fired condensing boiler. I have one and love it. Its capable of 98% efficiency and it only produces the amount of heat I need between 84,000 BTU's and 20,000 BTU's depending on the out side temperature. No sense in buring enough gas to make 84,000 BTU's when all I need on a 40 degreee day is 20'000. It also vents and gets its make up air through a 3" pvc pipe so there will be no need to rebuild your chimney unless you want to install a wood stove.
    Tankless coils are quite possibly the worse way to produce hot water. Seeing as you are installing a new system why not upgrade to a better hot water solution. I would go with your idea of a closed loop system with an insulated tank. The only change I would make is to get a tank with a back up heat source either a dual coil ( from boiler) or electric. Super stor has many options
    http://www.htproducts.com/superstorsolar.html
    To do this right and save money you are going to need several pumps there is just no way to avoid it. My boiler came with all the controls I need for DHW and heating The only controller you would need would be for the solar side, I know FWWebb is now selling complete systems so you might want to look there
    here is a link to my boiler
    http://www.buderus.net/OurProducts/GasFiredBoilers/GB142/tabid/92/Default.aspx
    Good luck
    Lou
  4. Breakitnfixit
    May 17, 2008
    Vermont
    Thanks for input, Lou
    I did investigate condensing boilers early on but stopped when I found out a drain was needed for the condensate. This must remain a basement installation and there is not a drain down there. I'm not keen on adding a drain and pumping out the liquid isn't appealing either. Are there other solutions I'm missing? I'm definitely not married to the oil idea but the solar piece needs to stay.
    Thanks
  5. BigLou
    BigLou New Member
    Nov 7, 2007
    breakitnfixit,
    Why are you opposed to a condensate pump ? they are like $50 and the simplist part of the whole project to install, just plug in the pump and run some clear vinyl tubing and your done Its a small trade off for the 15%- 25% jump in efficiency (assuming you can operate in the condensing range)
    We used 1350 gallons of oil a year with the old system it would have cost over $4000.00 this year. This past january my gas bill (biggest so far) was $135 for heat hot water and cooking, I just got my april bill for $56.00 I am expecting around $30 when the heat shuts off for the summer. If I had a solar back up it would be ZERO for the summer. So I am looking at about $1000 a year down from $4000
    Where in VT are you ? is natural gas available to you ? Another option would be a indoor wood boiler with a large storage tank that could do dual duty with the solar.
    Here are some pictures of my set up took during the instalation. It was not installed in an ideal location but you can see how we made due. I have a super stor but not a solar one ( it was here before I bought the house). If you look you can see the condensate pump and its drain line its really a non issue for the added benefit.
    http://home-and-garden.webshots.com/album/561572191MXzZYj?vhost=home-and-garden
    Lou
  6. jadnashua
    Condensate needs to go to a drain, as pumping it outside in the winter can be a major problem. Most pumps have about 12' of head and a fair distance, so you could go up to the main floor of the house and drain it somewhere there. A washing machine stand pipe provides a fairly convenient location to drain it most of the time. If the pump fails, some have an interlock float switch that will shut things down if it fails before you get water everywhere.
  7. Breakitnfixit
    May 17, 2008
    Vermont
    My first thoughts on pumping condensate were its another thing to provide power for, another hole in the house, another system to fail and protecting the water from freezing at -20 degrees. Since we have a septic system I'm not sure if I should add the extra load (a few gal/day?) but maybe that would be ok since the washer stand pipe isn't far away or is the acid content of the water bad for the septic?
    We're very rural so natural gas isn't available. Going propane would require removing my oil tank from the basement and adding the propane tank somewhere (outside, right?). However, I have flirted with the idea of replacing the 20 yr old 275 gal tank with two new 330 gal tanks anyway since my location makes oil delivery in winter a real pain (like having to plow and sand just for the oil truck). I was kinda thinking if my system were efficient enough I could get through most of the winter with just the two tanks filled (I avg about 950 gal/yr).
    I know I said I'm open to other plans, its just that I have put most of my thinking (hard work for me) into the oil route which I'm already familiar with. I suppose the cost would be roughly the same to go propnae given that I wouldn't have to do a new chimney (its pretty rotton looking from the outside anyway). I would also have to figure whether the condensing unit would always be running at max efficiency and what would I have to do to help it do so.
    The scale is kind of even between both oil or propane but I'd need some sound advice to get me to commit to starting my thought process over to get comfortable with going propane.
    Also, I haven't heard any negative comment on preheating the boiler inlet water with solar so either way I should get cracking on obtaining the needed hardware, right?
    Thanks
  8. Breakitnfixit
    May 17, 2008
    Vermont
    I should qualify my need for 'sound advice' to mean MORE sound advice. I'm not implying that any comments so far have not been helpfuL!. Thanks.
  9. BigLou
    BigLou New Member
    Nov 7, 2007
    If you go the tank route there is no need for the domestic hot water to pass through the boiler. There will be a two closed loop coils in the tank one for the solar and one for water from the boiler
    The problem with using a solar tank to pre heat for a tankless coil is what to do with the extra heat from the boiler. It will work great when the solar tank is hot enough to not kick on the boiler but your boiler will over heat in the spring an the fall causing the pressure and temperature valve to open and blow hot scalding water all over the place.
    IE all of the heat is absorbed when the inlet temp is 40 but in april when the solar tank is 80 the excess heat can't go in to the water with out over heating it . Those same BTU's will not go to waste in a tank where they can raise a greater volume of water a lower number of degrees
    If you want to go the oil route go for it. I just always advise people to go the high efficiency route. A new properly sized oil fired boiler with a solar hot water tank will still save you a lot of money. I have also been told that some oil companies will give you a better price on "bulk" delivery of over 500 gallons
    I hope you do get more comments here but most threads that involve design and sizing get very few replies here. There are some great plumbers on this site but I think the majority(both here and IRL) don't how to properly size and design a system or they just don't want to share the information. Cheap fuel and lazy people have made it ok for years to not do your home work and install the right sized system
    What ever you end up doing make sure you properly size the boiler by doing a heat load calculation for the home, don't just get the same sizre you have or let some one tell you what size you need based on the square footage of your house
    If you want help properly designing your system( what ever one you go with) including how many solar panels and where to locate them. feel free to post here or send me a PM and I will E Mail you
    Lou
  10. jadnashua
    The most efficient gas units use a condensing boiler, variable output, and an outside reset control. The Buderus unit I have is rated at 94.5% at full output, but as you modulate it down (it will fire at 20%), the efficiency increases as the same size heat exchanger can extract more heat when it isn't being fire at full power. The outside reset automatically adusts the boiler output temperature to match the load and to keep it running. Running it at 20% continuously is more efficient and more comfortable than running it at 100% 20% of the time. Once you've heated things up, and then things turn off, you waste a lot of that heat you paid for, but if you continuously produce just what you need, it is far more efficient.
    A modulating unit gives you more leaway in having a correct heat load assessment, but still needs to be considered or you would not be running it at the lowest point where it is more efficent most of the time (i.e., if that low point is far more than you need most of the time, you've missd the mark).
    I don't typically look at oil-fired stuff, so I do not know if they've been able to do modulating burners.
    As to the condensate, if you were worried about the acidity of the water, all of the manufacturers make an add-on neutralizing kit. Basically, it runs it through a bed of minerals to raise the pH. You could run it to a new drywell if you didn't want to run it to your septic system.
  11. I wanted to preheat water with solar energy before it went to my electric tank less water heater. The higher the temperature of the water going into the heater, the less electricity will be used to bring the water up to the preset temperature on the heater
  12. MikeP860
    MikeP860 New Member
    Nov 2, 2011
    Sales
    Brooklyn, CT
    CD, did you figure this out yet? I have a very similiar question posted in here. I have a relatively new oil burner with a tankless hot water system. I also have kids and every time they get in that shower, on goes the burner. I cringe at the sound and the fact that oil is still above $3 a gallon down her in CT. I also have circulating base board hot water heat. I also have 40-45 degree well water going in to the boiler. I built my own hot water solar collectors and I am very close to building the flow system indoors. I will be using a glycol based anti freeze mixture in my closed loop. I am running the hot solar water through a sidearm heat exchanger to the hot water holding tank. It's going to work...I tested it and I was giddy and smiling like I won the lottery for the last week. I need to know the same thing...if my oil fired burner pulls pre-heated solar water, versus near freezing well water, what are the consequences? Is there a better way?
Similar Threads: Solar Preheated
Solar and Geothermal Water Heating Forum Replacing Solar Storage Tank Jan 10, 2017
Solar and Geothermal Water Heating Forum How to disable my batch solar hot water heater temporarily Dec 8, 2016
Solar and Geothermal Water Heating Forum Plumbing Water Heater Into Solar Loop Sep 24, 2016
Solar and Geothermal Water Heating Forum Solar water heating optimization Jun 5, 2016
Solar and Geothermal Water Heating Forum Solar Assist For A New Boiler May 5, 2016
