Soil stack and venting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Tylock, Oct 17, 2013.
  1. Tylock
    Tylock New Member
    Oct 17, 2013
    Pittsburgh, Pa.
    Hello, I have an old rental and the soil stack stops at the first floor bathroom with a toilet on top of it which can't be moved. I replaced the old toilet in the basement plus added a wash basin. So those openings that were unintended vents are no longer and nothing worked, total vacuum. I snaked out the trap vent outside that was clogged and installed vents on the three sink traps. Everything works, but not great. There is a 5 inch iron pipe outside that comes out of the ground. It's to the side of the toilet in the basement 3 to 4 feet away. This pipe runs up the side of the house 30 plus feet and ends 3 feet above the gutter. Nothing is connected to this pipe on the exterior of the house. Do you think this is connected to the waste pipe underground? I plan on cutting it down in pieces for scrap then run a snake through it. If this is the vent and it dose work do I have to run a PVC pipe back up past the roof? What do you think?
    Thank you.
  2. hj
    I think your description is too convoluted to figure out what is happening, but the pipe outside, if it is a vent, is useless as far as your indoor piping is concerned.
Similar Threads: Soil stack
Plumbing Forum, Professional & DIY Advice Option for adding to my soil stack for second toilet. Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Need bathroom rough-in guidance: branch squeezed b/w WC and soil stack Sep 21, 2016
Plumbing Forum, Professional & DIY Advice Soil Stack Placement question Oct 14, 2015
Plumbing Forum, Professional & DIY Advice Soil Stack Offset? Jan 26, 2015
Plumbing Forum, Professional & DIY Advice Can soil stack make more than one offset? Dec 5, 2014
