Designie
This is our new house and we need a softener system as we are ready to have the hot water tanks and such installed. The plumbing has been on for awhile now, just to use toilets, test the fixtures and get water for mixing grout and such.
The well is 240 ft deep. The well log shows 6 gpm of flow from the well and a static water level of 30 ft. The submersible pump is a 10 GPM and I am seeing around 8-10 GPM flow at the pressure tank. I have a 32 gallon pressure tank with a 40/60 switch. The house has 3-1/2 baths and 2 kitchen sinks. My wife and I and 3 yr old twins will live there.
I had a comprehensive water test done by a local lab here in Michigan. Complete results are listed below.
Got a recommendation from Ohio Pure Water for a Fleck 2510 40,000 grain system, 1.25 cu. ft. resin with 10 GPM SFR and 2.5 GPM backwash. Also they recommended a RO system for drinking water.
Does anything look surprising about my water test? Anything you can add? We need a system soon, I don't want to start messing up appliances and hot water tanks. I really do not know much about softeners, can someone please recommend a system for me?
Thank You all!
Ron.
Water Test Results:
Physical Factors:
Alkalinity (Total) 210 mg/L
Hardness 120 mg/L
pH 7.7
Total Dissolved Solids 1500 mg/L
Turbidity 0.8 NTU
Inorganic Analytes – Metals:
Aluminum ND
Arsenic ND
Barium ND
Cadmium ND
Calcium 28.2 mg/L
Chromium ND
Copper 0.013 mg/L
Iron 0.066 mg/L
Lead 0.002 mg/L
Magnesium 12.50 mg/L
Manganese 0.016 mg/L
Mercury ND
Nickel ND
Potassium 5.2 mg/L
Selenium ND
Silica 9.460 mg/L
Silver ND
Sodium 514 mg/L
Zinc 0.013 mg/L
Inorganic Analytes – Other:
Chloride 620.0 mg/L
Fluoride 1.7 mg/L
Nitrate as N ND
Nitrite as N ND
Ortho Phosphate ND
Sulfate 170.0 mg/L
Organic Analytes – Trihalomethanes:
Bromodichloromethane ND
Bromoform ND
Chloroform ND
Dibromochloromethane ND
Total THMs ND
Organic Analytes – Volatiles:
1,1,1,2-Tetrachloroethane ND
1,1,1-Trichloroethane ND
1,1,2,2-Tetrachloroethane ND
1,1,2-Trichloroethane ND
1,1-Dichloroethane ND
1,1-Dichloroethene ND
1,1-Dichloropropene ND
1,2,3-Trichlorobenzene ND
1,2,3-Trichloropropane ND
1,2,4-Trichlorobenzene ND
1,2-Dichlorobenzene ND
1,2-Dichloroethane ND
1,2-Dichloropropane ND
1,3-Dichlorobenzene ND
1,3-Dichloropropane ND
1,4-Dichlorobenzene ND
2,2-Dichloropropane ND
2-Chlorotoluene ND
4-Chlorotoluene ND
Acetone ND
Benzene ND
Bromobenzene ND
Bromomethane ND
Carbon Tetrachloride ND
Chlorobenzene ND
Chloroethane ND
Chloromethane ND
cis-1,2-Dichloroethene ND
cis-1,3-Dichloropropene ND
DBCP ND
Dibromomethane ND
Dichlorodifluoromethane ND
Dichloromethane 0.003 mg/L - 0.005 EPA Primary
EDB ND
Ethylbenzene ND
Methyl Tert Butyl Ether ND
Methyl-Ethyl Ketone ND
Styrene ND
Tetrachloroethene ND
Tetrahydrofuran 0.02 mg/L - No EPA Rating
Toluene ND
trans-1,2-Dichloroethene ND
trans-1,3-Dichloropropene ND
Trichloroethene ND
Trichlorofluoromethane ND
Vinyl Chloride ND
Xylenes (Total) 0.002 mg/L - 10 EPA Primary
Thank You all!
Ron.
Water Test Results:
Physical Factors:
Hardness 120 mg/L
pH 7.7
Turbidity 0.8 NTU
Aluminum ND
Arsenic ND
Barium ND
Cadmium ND
Calcium 28.2 mg/L
Chromium ND
Copper 0.013 mg/L
Iron 0.066 mg/L
Lead 0.002 mg/L
Mercury ND
Nickel ND
Potassium 5.2 mg/L
Selenium ND
Silica 9.460 mg/L
Silver ND
Sodium 514 mg/L
Zinc 0.013 mg/L
Chloride 620.0 mg/L
Fluoride 1.7 mg/L
Nitrate as N ND
Nitrite as N ND
Ortho Phosphate ND
Sulfate 170.0 mg/L
Bromoform ND
Chloroform ND
Total THMs ND
2-Chlorotoluene ND
4-Chlorotoluene ND
Acetone ND
Benzene ND
Bromobenzene ND
Bromomethane ND
Chlorobenzene ND
Chloroethane ND
Chloromethane ND
DBCP ND
Dibromomethane ND
EDB ND
Ethylbenzene ND
Styrene ND
Toluene ND
Trichloroethene ND
Vinyl Chloride ND
